Just a few days ago, I posted my first question here - asking about a personal system for a home in Africa. I also have spent time reading a lot of the entries here regarding the implementation of offgrid solar.
One thing that struck me is that, it seems most of the contributors ( or "helpers" , if you want ) to discussions about implementing solar in Africa don't quite seem to understand the basic premise of why people are looking at PV based solutions. They assume the following:
The reality is as follows:
So, you can see, it is very easy to size a system with the above parameters that easily exceed what people expect from a typical home based system here in the States. Ideally, for a typical user considering a PV system in an urban area and some applications in the rural areas ( schools, clinics ect), what is needed is advice on how to smartly configure a system to minimize cost, whilst providing coverage for most of the loads provided and at the times when they are needed. Advice about alternatives to the equipment we use - e.g. if AC units are a must, then what are the best solutions out there ( instead of advising that AC units are a no no ). I am particularly intrigued by users here who seem to have adopted some sort of process to manage the use of PV power during the daylight hours and at night ( e.g running certain appliances only at certain times).
Perhaps, will be great to have a good discussion about this - assuming that you had to run loads with high power requirement like ACs and refrigerators, what will a smartly and optimized system to do so look like? I provide a sample load sizing scenario below as a starting point. Take it apart and lets see the most efficient system you can design for this - maybe this can be a sticky for everyone in this situation.
Ultimately, I suspect for the situation I describe above, the solution may not be just implementing a PV system and managing usage, but rather a much more broader approach to how we build our houses - making them green as much as possible to reduce the dependence on energy sapping appliances. Also, perhaps, with time, advancements in battery tech will remove the restrictive cost of this component in a solar system, making it truly affordable as a cost effective replacement for grid power - not because we want to stick it to anyone or are on some crusade to be offgrid at all costs because it is cool to do so, but purely out of necessity. It is a necessity for us and the advice towards building and optimizing a system should take this into account . Thxxxx
sample load requirement: ( totally made up )
Note that we are on 220V @ 50HZ.
- Grid power is mostly available / dependable so always size your system purely as a backup for critical loads. ( or even, potentially, charge your batteries with grid power when available, thus minimizing the investment in array size )
- load requirements based on the above will be very small - anything creeping beyond a 5kw system is ludicrous.
- to minimize the size and cost of systems, why not use a genset as a backup to the PV system
- The problems with the grid makes it almost totally undependable as a power source - availability has become increasingly erratic beyond what you can imagine here in the US. Power being off is now the norm. Even when its available, the quality leaves much to be desired.
- To solve this, people have already used gensets as a readily available solution. They have become the main source of power in some cases. But it has its downsides. Initial cost, cost of gas to run them and maintenance. Compared to smartly and efficiently sized PV systems, gensets loose out. I recently read an article from the BBC about the noise and pollution levels of gensets running in Lagos, Nigeria on a typical day. Just bad. Imagine the cacophony of rattling gensets all day. People are imagining a shift to a solution to completely replace gensets if possible.
- Load requirements are 24/7. During the day, when the grid is on the fritz mostly, people still want to power the usual things - homes have wall mounted ac units, refrigeration units and freezers and perhaps kitchen appliances that draw power. Businesses have all sorts of needs - again, ac units for offices or for those in the services business ( hotels ) ac units for guest rooms, office computers to run etc. During the evening, the emphasis is on lighting, refrigeration and something to provide comfort from the stifling heat ( the main reason why the wall mounted ac units were purchased in the first place).
load | quantity | use per day | freq. per week |
ac unit | 2 | 6 | 7 |
fans | 2 | 4 | 7 |
Compact flourecents | 15 | 6 | 7 |
TV ( 50+ inches) | 1 | 6 | 7 |
desktop pc | 1 | 4 | 7 |
laptop | 1 | 4 | 7 |
refrigerator | 1 | 6 | 7 |
freezer | 1 | 6 | 7 |
microwave | 1 | 0.1 | 7 |
blender | 1 | 0.1 | 7 |
wall plugs | 5 | 2 | 7 |
water pump | 1 | 2 | 7 |
water heater | 1 | 2 | 7 |
