$250 Budget Inverter -12 dc volts in, 3,500 watts at 120 ac volts out. How is this legal ? I could literally create a 300 amp dc current in my shed without realizing it. Man I could cook a whole side of moose in an hour with that kind of current. I guess that if you became a conductor of this circuit it would be fatal right away?? I can not find a corresponding cable reference on ANY 12v voltage drop tables, regardless of wire size. Not even close. I imagine you would have to use solid 1/2" copper bar stock or close to hook up your battery .
Now THIS seems like a very dangerous device to me.
You can always put a 100 Amp fuse / breaker on the DC input, if that's what you want to limit it to. -
We get calls from people who have 10kW 12V inverters they bought elsewhere. Scares the CRAP out of me, I won't touch that system, I won't help them.Solar Queen
altE StoreComment
There are several issue involved and all have to do with resistance.
1. It is very unlikely any DIY or non professional could ever terminate a cable properly. It takes very expensive 15 ton hydraulic compression tools with the right dies to properly terminate a cable with a compression connector.
2. At 300 amps requires a minimum 2400 AH battery to safely deliver 300 amps. A 2400 amps battery terminal post are massive with 4-point 5/8 inch holes to terminate a 2 or 4 bolt terminal connectors requiring 50-foot pounds of torque.
3. The Inverter in question terminals are no way designed or capable of terminating a properly sized terminal to handle 300 amps.
Ever see one of these or know what to do with it? Try to find a place to connect it to your battery or inverter.
All it takes is as little as .01 ohms connection resistance to have an explosion, and I promise you cannot get a connection resistance that low on the inverters. The terminal need 2 square inches of connection surface area and 2 bolts to make and keep it.
But the world is full of fools foolish enough to buy the equipment and oblivious of the dangers and even deny it like Willy.Attached FilesMSEE, PEComment
But the world is full of fools foolish enough to buy the equipment and oblivious of the dangers and even deny it like Willy.Comment
ScreenHunter_999.jpgComment
Too bad it cannot be used in any code compliant system. Seriously it is cheap junk. Just a single die cost more than that.MSEE, PEComment
It's used everyday on code compliant crimps, get real. Do you think the DC cable lug is a NEC certified crimp ?? Show me the certification on the one you posted.Comment
No possible way the dies are not coded or listed. A Listed die alone will cost you $100 and more. $39 would not even buy the raw tool steel they are made from.
NEC certified certainly not as they do not certify anything. NEC does require all materials and tooling to be certified by a recognized testing agency like UL and CSA. Burndy T&B compression materials are listed with UL and CSA and each compression terminal has the listed tool and die codes required.MSEE, PEComment
YNo possible way the dies are not coded or listed. A Listed die alone will cost you $100 and more. $39 would not even buy the raw tool steel they are made from.
NEC certified certainly not as they do not certify anything. NEC does require all materials and tooling to be certified by a recognized testing agency like UL and CSA. Burndy T&B compression materials are listed with UL and CSA and each compression terminal has the listed tool and die codes required.Comment
Sunking is correct. On a project that is reviewed to meet NEC, items like cable termination require certain verification that they were done correctly. Using dies with certification listing that get embossed into the wire termination is one way the Inspector can see the proper tool was used.
Sure you can use any crimping tool you want for your RV or home, but should a fire happen and the investigator finds improper wiring, non UL listed devices or code violations chances are the Insurance company will not pay for damages. Should someone get hurt and violations are found then liability will fall on the person who did the work and criminal procedures could follow.Comment
