Ok, hello! Quickly I am not totally new to off-grid solar but the longer I am in it the more I realize I know so little. This particular question deals with input voltage specifically. Oh... and before anyone says throw more $$$ at it... I am on a limited budget so that is not a viable option right now. Have to make due with what I have.
Now that being said:
System:
- 5 panels 24VDC 1.24kW potential
- 1 Outback MPPT 60A charge controller (12/24/48)
- 1 Tripplight 24VDC - 120AC inverter / charger
- 8 US Batteries 24VDC @ 760AH capacity
Everything is set up for 24VDC, but I saw somewhere that you could set the panels up at a higher voltage and that would increase efficiency. I am not an elecrician so this is where I get hazy. Wouldn't my kW capacity drop?
I know that in order to do this I would have to get 1 more panel or drop one panel out of the system. I also understand from what I was able to gather from the Outback literature that I can run the panels at 48VDC and the charge controller would make the required voltage step down for the batteries.
So is this a more efficient way to run the panels? And if so... why? Thank you for learning me!
System:
