2 panels for grid tie ?
  • dee
    • Mar 2015
    Hey Mike,
    I need some info, and you seem to know what your talking about. hopefully you can help me.
    I am trying to get into solar, I am going to go straight into grid tie stuff. I hooked up my parents with solar on their cabin, with battery backup. It has been fantastic.
    Now I am stepping into something different.
    Question-
    I have 2- 120w Pmax panels that are identical with a 7.12A max. I want to hook to a grid tie unit with possible upgrade or additional panels later on what size inverter should I purchase? I am thinking 600w 10.8 - 30VDC.
    I also have two different panels, I am thinking about hooking to a grid tie inverter. One is a 90w Pmax, 5.55A max, and the other is a 75w Pmax, 4.8A max, that I want to hook up, was thinking about the same inverter, 600w 10.8-30VDC.
    Then, if I understand I can plug them into a power strip and directly into the wall. Does this work?
    I have a 100 amp box with a breaker that I was thinking about wiring into and out of as a way to disconnect if any problems arise.
    Do any of you foresee problems?
    Any help you can give would be appreciated, as I have stated I am new to this whole thing and need the info.
    I really believe in solar wind and alt energy.
    Originally posted by dee
    Then, if I understand I can plug them into a power strip and directly into the wall. Does this work? Works great for the crooks selling the plug in grid tie inverter. Not legal to use in the US for one thing. Not UL listed so in the event it causes a fire you get to pay rather than the insurance company
    Solar is great - in it's place and commercial wind has applications while residential wind is possible in a few percent of total area of the US. Residential wind you see on the net is generally junk.
      Sadly, this is illegal and unsafe to do. Just like stores can sell glass pipes for smoking crack, it's not legal to do so.
      Plug in grid tie systems can easily overload a circuit and start a fire in your house.
        Even if they do not just catch fire on their own, not being approved for safety by any listing agency.
          Have to agree.
          The plug in systems are not Safe
          The only way to do this is with a Microinverter system such as Enphase etc that will meet the input voltages of your panels.
          And this cannot be a plug in system but hard wired and approved by the AHJ and utility it will be connected to.
