Originally posted by toothy
View Post
Aquions How low can I go?
AlmostOffGridHawaiian -
Originally posted by Living Large View PostongridHawaiian is in HawaiiAlmostOffGridHawaiianComment
Off/on/whatever works Hawaiian
Like I said I have never really used the auto start feature in the last 6 or so years off grid. I tried it for a while but it doesn't think about tomorrows forecast. I remember it ran one night after a long cloudy period, kicked off at float and then we had a sunny day and the whole run cycle could and should have been avoided. So, no more auto start for me.
I think the Aquions will allow me more freedom and I'm thinking I may go back to using the auto start with them, but differently than with fla's. Set a low soc % or volt start with a short 1-3 hour run time and let it cycle like that if bad weather persists, and never worry about making it through absorb.
I think you should hook your gen up and forget the auto start because your array and weather conditions are better than ours. Use the auto start relay to power a buzzer as a low volt reminder.
WadeComment
After 6 years off grid and your not using the the 50% to 85 % soc recharge scheme when using the Generator auto start to fill in for your solar during bad weather ?? It's no wonder FLA batteries get a bad rap. The only reason you'd need to run to float would be if you were forced to do a EQ . Doing a full charge is only needed every 7-10 days and even that can be extended some as long as your watching your SG's.Comment
Originally posted by toothy View PostLiving Large,
We are off grid, no wires from the outside unless you count the phone and that is not much use for juice.
We use between 5-10 Kwh per day we have 2 arrays one @ 2000w and one @ 3000w and a 1kw wind turbine.
We don't get much real sun in the late fall and early winter. I just can't stand worrying about damaging the FLa's,
I'd rather recycle them than think about them.
I take it your run times a calculated not real world? To get those short run times you must have quite the generator and charger. My inverters don't have a lot of umph on the charge side 2-Outback vfx3648, they seem to max out around 70A DC. I did just install 2- SW5548 as chargers only and they seem to put out a bit better.
On the Aquions, not having to worry about 100% soc on a regular basis, or ever, would make my life a lot easier. I really never use the gen auto start, it works and all but it is not the way I'm programed. I would rather turn it on when I wanted run it a few hours and hope for some sun or wind in the next day or 2.
Wade
I am in agreement as far as maintenance of FLA, based only on what I have read. People here warned me I would essentially have a new child to take care of. For my particular application, it was not for me personally but I know it is the standard choice. Good luck. If you go AHI, please post an update on your experience.
Don
Edit For the LFP batteries I was looking at, the charge rate is C/5. For AHI, I believe it is C/16.Comment
I manually recharge when in the 50-60% range, but I have to think about it ALL the time. Not because I would be upset if I had a low voltage disconnect but because a lvd is bad for the batteries. I do stretch full recharges a bit but there are as many theories on how many days is non damaging as there are backsides. I never run gen into float only to float every 10+/- days.
No kids, I heard you can't get rid of them even if they are a pita, my Rolls 4ks25ps's are totally disposable when they become a pita and are truely unloved.
Do you have the charge capacity to achieve you projected run times? C/5 is great if your gen and charger can hack it.
WadeComment
Originally posted by toothy View PostI manually recharge when in the 50-60% range, but I have to think about it ALL the time. Not because I would be upset if I had a low voltage disconnect but because a lvd is bad for the batteries. I do stretch full recharges a bit but there are as many theories on how many days is non damaging as there are backsides. I never run gen into float only to float every 10+/- days.
Wade
With LFP you have concerns of too low a voltage killing em in one very unhappy expensive incident, but you can plan to avoid that. There was extensive discussion on this site about how to design for an LFP bank, including balancing, practical DOD range, and LVD. For me personally, they were a much better fit.Comment
LL
I don't have Schneider xw stuff but beware neither of my set-ups put out their rated charge amps. My 2-vfx3648's rated 90A actual output around 70A DC. On my 2-SW 5548's it's around 30A on the AC side rated 35A.
WadeComment
WadeComment
