  • OftheSeven
    • Jan 2015
    • 50
    Started solar, now have to do roof
    I signed the paperwork for solar (a 4.6kW system - 17 Suniva Opt270 modules and 17 Enphase M215 micro inverters).
    Installation of the roof trac started last week and they said my roof had about 5 years of life left, hmm. Well, one area over a space with no attic (room addition) wasn't as lucky and can't be used in its current condition. All work is on standby now as I wait for roofing estimates.
    Of course this throws a wrench into things. It comes down to economics but thinking of three roof options:
    1. Address the area that is needed to continue and leave the rest.
    2. Address the area that is needed to continue + the south facing areas where panels will be mounted so I don't have to deal with it in 5 years.
    3. Do the entire roof and rethink solar (but why do the roof now if I'm not doing solar)?
    The company I'm using will remove panels at a later date if I'm roofing but I don't know if I should just try to address it all now. Thoughts?
  • Alisobob
    • 605
    My solar sits on the south facing side of my 20 year old roof.
    This is exactly why I redid the south facing side roof, at the same time I did solar.
    Its done, and I dont have to think about it again... ever.
    • deezeela
      • Feb 2015
      I was told the preparation work needed for solar is also eligible for 30%
      fed. tax credit.
      If option 3 is 100% eligible for 30% FTC, I would go for option 3, since only 5 years life left. Otherwise, option 2.
      • HX_Guy
        • 1002
        Originally posted by deezeela
        fed. tax credit.
        This here.
          • 14920
          When roof maint. is required/chosen (and IMO, always at least something to be considered, and probably done if only as cheap insurance), most often the work is somewhat limited to the area around the array, particularly, and as a min. above and below as well as under the array. I'd check with my tax adviser on applicability/limitations of applying a tax credit to roof maint. Some folks do it, some don't. Point is, qualified opinion from a CPA might throw more weight in an IRS audit than some unvetted opinion found on the net.
          • Alisobob
            • 605
            My accountant said if the solar install disturbed the roof in any way.... then the corrections to the roof in the solar areas are part of the solar "install", and the credit applies.
            Outside the solar area, no credit applies.
            • HX_Guy
              • 1002
              So looks like option #2 is the winner.
              • OftheSeven
                • Jan 2015
                • 50
                Thanks for the info Bob! So if I do my entire roof, I have to deduct the area not 'affected' by the solar? What if I'm running conduit and electrical related to the panels under the roof area w/o panels on top?
                • HX_Guy
                  • 1002
                  The solar tax credit is pretty vague. It says the credit applies to "site preparation" and I would assume any part of the roof that solar components lay over would qualify. It's a pretty gray area and I'm actually surprised how little goes into verifying what people spend on solar. It's basically an honor system (though I guess so are taxes in general, but at least those are backed up with W2s, 1099s, etc...whereas with solar it's just a form that you put a dollar amount on...no receipts etc.).
                  • thejq
                    • 599
                    In general all tax advice you get on this forum is always YMMV. That said, if you can reasonably explain your understanding of the tax code when it comes to audit, even if you're found wrong, you're only required to pay back taxes and maybe nominal interest rate. It's because ignorance is not fraud. It's different from if you intentionally tried to hide something (like other income etc.) or overstating costs (double charging etc.) which could result in huge fines. Also if you're self employed and audit prone, it's better to be extra careful.
                    16xLG300N1C+SE6000[url]http://tiny.cc/ojmxyx[/url]
                    • silversaver
                      • Jul 2013
                      • 1390
                      He is right, just a form you need to fill out on. Solar cost from $3 to $6 per Watt DC installed, so do your own math and find your balance. You need a receipt for your accountant and youself just in case....
                      • thastinger
                        • 804
                        And you'd almost be stupid not to take it whether you have PV or not. If you got audited there is nothing to say you didn't have it removed the next day...not what you know, it's what you can prove.
                        1150W, Midnite Classic 200, Cotek PSW, 8 T-605s
                        • HX_Guy
                          • 1002
                          That, would then be fraud. It can be proved pretty easily if you actually had solar (permits).
                          But I have a feeling you were joking.
                          • Alisobob
                            • 605
                            Thats what I did....
                            The North side is supposed to outlast the South side 2:1, according to the roofers I spoke to.
                            Less sun exposure was the #1 reason given.
                            My roof should outlive me....
                            Its poured rain a few times since my install... Zero leaks.
                            I sleep well at night.
                            Getting your roof in order before solar , cannot be ignored.
                            • Alisobob
                              • 605
                              See my original answer.
                              If it disturbs the roof, I'm taking the credit.
