How many batteries with a 160 watt solar system?
  • Filter
  • How many batteries with a 160 watt solar system?
    I have enough solar panels to equal 160 actual watts of output in fairly bright sunlight. I also have a Xantrex controlled that can handle up to 60 amps of input current.
    How many deep cell batteries can I charge with this setup based on a very light load?
  • #2
    Depends on your location. If you live up north only around a 75 AH battery at 12 volts, up to 150 AH if you live in Arizona.
    What do you mean by a tight load? Systems are designed around the amount of power you use in a day and your location.
    • #3
      I was hoping you would say 5-6 deep cycle batteries lol. I live in the high desert of California. Lots of sun. What I mean by light load is that I will not put any draw on the batteries at all for weeks at a time.
      • #4
        Sorry to disappoint you but it is a simple physics problem.
        You say high desert but that does not answer the question of your solar insolation. But for argument sake let's say you get a 4 Sun Hour Day. The most power your 160 watt solar panel array generate in a day with a battery system is 160 watts x 4 hours x 66% efficiency factor = 422 watt hours at best.
        Ok to size the battery properly you select a size based on 20% discharge per day. So with 422 wh we can multiply by 5, so 422 wh x 5 = 2110 wh capacity. Now to find the battery amp hours all you have to do is divide by the battery voltage so 2110 wh / 12 volts = 175 Amp Hours.
        So as you can see from the example you design based on your daily power requirement and location, not buy something and pray it works.
        • #5
          Looking at it another way, 160W of panels, gives you 130W of power (after de-rateing) at 14V, (standard charging voltage) thats only 9.2 amps. That would maintain 9, 100ah batteries, but if a battery is discharged, you would not have enough power to recharge it before it begins to sulphate, and degrade, from not being charged. Might take 4 or more days to "top off" the battery bank, and damage is done after 24 hours.
          2 batteries would be rechaged in 2 days, preventing damage. After a year of weekends, you could have 5 dead batteries, or 2 working ones.
