Need help understanding series parallel
  • Jovan
    • Jun 2014
    • 5
    I have four 6 volt 225 ah batteries right now in series. I'm gunning to get set up in series parallel and i've read and watched a bunch of articles and vids trying to get a handle on it. every time i think i get it I see something a bit different that throws me off. My system is a 24 volt inverter and i'm going to get 4 more batteries for a total of 8. Can anyone show me exactly how these batteries should be set up for 24 volts in series parallel?
    take this video for example, https://www.youtube.com/watch?v=VYhH...etailpage#t=94
    if i just set up all 8 batteries like what they're doing, i would get the results i want right? Or is there more to it than that?
    I didn't watch the video, but the series parallel wiring you are describing (diagonal wiring) is also illustrated here. One of the illustrations shows exactly the 8 x 6V configuration you are interested in, yielding 24 V. Gory details on the effects of unequal resistance are explained here.
    With four new batteries and four older ones, I would guess you want to split them up so that you have two of each in each series, but others with more experience may have other ideas.
    • Jovan
      • Jun 2014
      • 5
      From the diagram and what they're saying, this set up would only get me 450 ah, granted this may very well be enough for my needs if i play it smart until the bank kicks the bucket but if it's at all possible to get more ah i'd like to take a shot at it. If this is the case, would there be any way to bump up the ah a little more like by connecting all the positives to positives on the left of the pic and negatives to the negatives on the right? or would that case a major problem?
        450 Ah at 24 V is the most you can get from your batteries.
        • Jovan
          • Jun 2014
          • 5
          I see. Looks like I misunderstood how the ah stacked.thanks alot, you saved me from screwing up. I'll be getting batteries with more ah after these set go down.
