Solar Panel Generation Factor for Ludhiana, Punjab, India?
  • kicglobal
    • May 2010
    • 22
    Good Morning!
    We were going through how to design a Solar PV System, but got struck at a point how to derive Panel Generation Factor for Ludhiana, Punjab, India? As it is established for Thailand 3.43 and 2.93 for most of the European countries .
    Would you pls. be kind enough to explain the formula to arrive at this figure step by step? Looking forward for your expert advice.
    Thanks a lot in advance!
    Regards ?
    Sandeep Kumar
    Welcome.
    Here's a world wide site http://rredc.nrel.gov/solar/calculat...ATTS/version1/
    right side lists the world regions.
    http://www.pvwatts.org/ has several caculators on their home page that may be useful.
    Enjoy.
    Mike
    • AngshumanPatra
      • Feb 2012
      Re:Your Query about PGF
      Hi Mr. Sandeep
      Hope you already got your answer if not i suggeest you a solution hope it will serve your purpose:
      EXample: Wp=75W,Isc=4.8A,Voc=21.4,Im=4.4A,Vm=0.605 sq. meter
      FF=(Vm*Im)/(Voc*Isc) = 0.718
      at STC
      Efficiency= (Voc*Isc*FF)/(It*A)*100% =12.36% (at STC It=1000w/sq meter)
      If you know the avg radiation (let =616 w/sq meter)
      Actual efficiency at 616 wper sq. meter = 12.36*0.616 = 7.61%
      Power produced by the module=0.0761*616*A(0.605) = 28.36 w/hr
      Let Sunlight available = 8 hrs per day
      So total power generated by the module = 28.36*8 = 226 watt/day
      Let your required power is x watt
      Then PV module needed = x/226 =y no.
      • benzac
        Dear Mr.Patra
        In the formula "Efficiency= (Voc*Isc*FF)/(It*A)*100% =12.36% (at STC It=1000w/sq meter)", What is the value of A?
        "If you know the avg radiation (let =616 w/sq meter)", Why it is "Let 616",, Why not actual?
        Please Clarify
        Benny Zacharia
        Originally posted by AngshumanPatra
        Hi Mr. Sandeep
        at STC
