Your batteries should be discharging, recharging or resting at full charge. Leaving them sit partially charged is damaging.
The time to light the candle and cut back on the puter time is when the clouds roll in and you still have battery power to conserve. Not run at full speed till there is nothing left.
In our trailer the big loads can drain the bank in short order with out the solar assist. So when the clouds roll in the big inverter goes off. The TV is limited to a few hours a day IF there is something to watch. Doing so means the banks will last a week if they had to, not that I would allow it.
One way or another you need a back up means of charging be that a generator, your trucks alternator or for us the last resort is turning the truck around and using jumper cables.
