OK. So the event is to power a dc motor to power a boat using solar panels or a battery.
I will stick to my first statement that the people who thought up this event may not understand solar and batteries or expect you to design the system without telling you all that you need to know about basic electricity.
If the kota motor is only rated 12volt then using a 250watt panel that has a Vmp of more than 18volts can hurt that motor by exceeding it's voltage rating. So you will need to go with a 24volt motor and 24volt battery to truly compare solar panel power against battery power.
I can also tell you which power source will make the boat travel the furthest but maybe that is what you have been tasked to do so I will stop.
