View Post
7kWh per day off grid design for Adirondacks - critique wanted
MSEE, PE -
Originally posted by Living Large View Post...
Mike - I'm curious of whether the charge controller and inverter/charger have to be in sync or on the same page. My understanding is the Xantrex controller and inverter/chargers let each other know which state of charge the batteries are in. What happens when you have a MS Classic (which I am also considering) controller and an XW inverter/charger? The ePanel seems to be designed to team the MS controllers with the Xantrex equipment, so I assume these play well together?...
As for charging, the battery spec is what you want to set all the chargers to, and the you look at the discharge/cycle life curve to set where you want the Inverter to disconnect. I use 4 sources to charge from, an IOTA line powered charger (from a generator), the internal charger in the XW inverter, Morningstar MPPT 60, Midnight Classic 200. Since I have an odd battery voltage, I just program in the setpoints for each of the smart chargers (the IOTA is pretty dumb, just a 54V DC powersupply). The Classic even has a "tweak" to fine tune it's internal voltmeters to match an outside reference (I use the Morningstar as the reference). So mixing brands that don't have a common data buss (battery full, all chargers discontinue), just lets one charger throttle back slightly before the other one drops back to FLOAT. In real life, it's not a problem.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Originally posted by Mike90250 View Postan IOTA line powered charger (from a generator), the internal charger in the XW inverter,
AmySolar Queen
altE StoreComment
Originally posted by Mike90250 View PostThe ePanel is a nifty wire box with all the goodies to make connections easy. Buss bars, breaker mounts, knockouts....
Thanks for more tips.Comment
Originally posted by Amy@altE View PostMike, I'm curious, why are you using an Iota and the internal XW charger? What is the power source for the internal charger? I would think you would have the genny connected to the generator input on the XW, and use the auto gen start, making the Iota redundant. What am I missing?
Amy
I have an antique diesel generator (hand crank, 400# of flywheel) that does 3Kw @ 240VAC that charges through the inverter. No auto start on this critter.
If the inverter just out and dies, solar charging is the norm in summer, but in cloudy winters, generator is my only option.
photo is from the web, now that my engine is built into the shed, I can't get a good photo.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Very cool, glad I asked, I figured it would be a good answer. I was right.Solar Queen
altE StoreComment
