Maybe after 30 minutes depending of the fuse type. However that is a moot point, no FUSE IS REQUIRED or needed. It is just useless hardware. The inverter being a mobile inverter has the protection built in.
Riddle me this. What happens to a 12 AWG wire with say, 3, 5, 10, or even 20 amps flowing through it continuously?
Answer: Nothing as it can safe handle up to 30 amps in free air all day long. To feed it into a breaker panel would require you to use a 20 amp breaker in the breaker panel. Now ask yourself this. What good does it do to have a 300 watt inverter supplying a AC breaker panel? A 300 watt inverter is made to have one very small AC circuit like your laptop power brick plugged into it. Not wired into a premises wiring system.
