Originally posted by Gyro
View Post
2) Customer service is great you guess - wow - NOT!
3) plug and play? Where
4 product description for a 12 volt lamp - generally meaningless and incorrect chatter.
- Adds nothing to your power bill. Unaffected by power outages. true
- 12V direct-current system is simple and safe enough to install yourself. Generally installs in under 2 hours with basic tools. Depends on how and where - meaningless statement
- Includes 5 Watt solar panel, charge controller, 12 Volt 5 amp-hour battery, bright LED light fixture, and all required mounting hardware. A 5 whole watt panel
- Can be controlled using integrated switch or by adding a remote control or motion sensor, or on a schedule by adding a timer.
- With optimum placement of solar panel, light can be used 5+ hours every day (drains battery only as much as a day's sun puts in). Emergency use for 25 hours straight (completely drain battery) without any solar recharge emphasis on the optimum placement - such as in front of a bright lamp. Depends on weather and insolation
