Help please
  • wannabe Hippy
    • 6
    Help please
    I recently purchased an off grid home, all was well till the shorter days , I find myself running the backup generator 2 hours a night to keep my battery bank ( 8 x 100ah gell) up above 12.4 v.
    The only thing running on the batteries is water pump and our lights.
    We pee outside to minimize flushing and turn on one 8 watt led for a few hours at night.
    I have 4 x 100 watt shell energy panels (sm 100 12p) with a 2.8 kw magnum inv/charger. I find it hard to understand why 8 batteries can't keep a charge with only one light on and everything else is unplugged.
    We use very little power( no appliances, toasted, hairdryer, absolutely nothing)
    Do the batteries need replacing?
    Can I replace with 2/350 amp hour vs 8x 100 am/h?
    Please help
    Jason
  • maple flats
    • Oct 2011
    • 108
    If all connections are good and the proper gauge cable, the batteries may be junk. Having a 12V set up is rather hard to do. It requires far too much cable expense to get good current flow.
    To answer the question of batteries, any time you can use fewer batteries to get the AH you need is better. Your first step is to work your needs, then from that determine what the system should be. It is very possible your system was assembled by someone who just bought components without any knowledge of what or how to do it.
    6,32 KW solar, net metered, maple syrup producer.
      Jason Gel cells are the last thing that should ever be used. Time to replace them. Having said that 400 watt of panels can only support a 12 volt 200 AH battery. You have 12 volt 800 AH. Your panels and controller at best can only support a pair of 6 volt golf cart batteries.
      • wannabe Hippy
        • 6
        Ok, so what needs to be replaced?
        Batteries, panels ...
        Will the inverter be ok? It has a manufacture date of 2010, I have a 50 amp mppt charge controller.
          Easy, start with batteries, a pair of Trojan T-105RE.
          • wannabe Hippy
            • 6
            Great I guess the solar dream is over, I've already invested more than I should have in this place.
            Generator and battery bank it will be.
            Thanks for the help.
              You learned something today. That something is the difference between your daily need and Demand. Solar can meet your needs over a period of time, but cannot meet your demands of energy every day. You have to have a conventional source of power to meet your demands. So if you want solar, you must also build a conventional source to replace it standing by hot and ready to go. With solar you pay twice. Once for the dream you found in that Bong, and agian when you sober up and find yourself without power with a generator or conventional power generation.
              • sdold
                • 1424
                It's been a long time, but isn't smiley using this thing backwards?
                • wannabe Hippy
                  • 6
                  Am I dreaming to think I can make this work with 4 newer panels and 3 trojan batteries?
                  With generator backup? Still keeping upgrade cost low?
                  Why can't I use this inverter?
                  Who can direct me to someone with straight forward answers instead of lessons of the day?
                    You first asked only about replacing the batteries and when somebody told you what kind of batteries to get you decided to give up. Nowhere did anyone say that you could not get by with just replacing the batteries and the panels, but the very first thing you need to have to get the right answer is an accurate estimate (or preferably measure) of how much energy you use in 24 hours. Buy a KillAWatt power meter and start measuring.
                      Who can direct me to someone with straight forward answers instead of lessons of the day? ......
                      The batteries are shot. Do you have a pressure tank in your water system ? That will help reduce the pump starts.
                      Adding more panels and their own charge controller will help.
                      But first, count up all your loads like this:
                      Light 8w x 6 hours = 48watt hours
                      pump 900w x .3 hrs = 270 wh
                      laptop 90w x 4 hours = 360
                      and so on.
                      Your inverter has to be large enough to start the pump motor, but all that "largeness" also means lots of idle power waste.
                        If you are referring to Trojan T-105 batteries, then you are dreaming. Better said do not understand. The T-105 batteries are 6 volts. No way to use three 6 volt unless you want a 6 or 18 volt system.
                        Any off-grid system requires a generator and must be included in the budget.
                        All of your questions have been answered in the order you asked them. However that is a moot point. The question you must answer before going forward is to determine your daily watt hour usage for worse case. Once you know that along with location, then you can proceed with a design.
