Rotating banners with links
wire size to inverter
I have a 85W panel with MC-4 connectors.
What size wire do I need to connect it to the solar converter I have.
It's a 300W solar inverter.
tia
depends on how long the wires are.
Originally Posted by
ant58
10' tops.
Let's make sure of the details. What is the panel voltage? How many panels - just one? If more than one - are they arranged in a string, or all paralleled?
Finally, what is the Isc Short Circuit Current rating of your panel? That sets the wire size.
lile001
Using 12 now.
1 panel, 12V
ant58
Using 12 now.
1 panel, 12V
Well the Isc will be a little more than this, but it'll be close enough. 85 watts / 12 volts = 7 amps. The smallest NEC wire size commonly used is #12 which is good for 20 amps. So a # 12 will handle your panel nicely. #10 is the next size up, and will also work. The wire should be RHW-2/RHH (type USE-2) sunlight resistant wire. If you have an MC4 connector on the panel, just get a set of cables already made up with MC4 connectors from any good solar supplier. If your inverter has terminal inputs, get a cable twice as long as you need, with male and female connectors on either end, and cut it in half.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
