Hi,
This is my first post and I have gone through several forum to find what I am looking for. So pls be nice. This is my first solar experiment. If everything goes well, my plan to harness most of my electrical needs through solar.
I purchase 6 uni-solar 136 watts 24v panels to put on the roof of my trailer. When the trailer is parked at home, my goal to use an inverter to generate electricity for home use.
NOCT
Pmax: 105W
Vmp: 30.8V
Imp: 3.42
Ideally, I would like to install the panels in Parallel for all 6 panels.
The problem that I have is that when I put all 6 panels into Parallel, the total Imp = 20.52 which is 3.42 * 6. According to wiring size chart, I should use 8 gauge wire. I believe the junction box wires from the panels are 10 gauge. It appears that all solar panel wires are either 10 or 12 gauge.
I know that I can have 2 pairs of panels (3.42 + 3.42) in series and 2 panels (3.42+3.42) in parallel = 13.68A where I can use 10 gauge wire.
I also have a limitation on the inverter: iMeshbean® 1000W Gird Tie Inverter MPPT Pure Sine wave for Solar Panel System DC 22V-60V TO AC 110V/120V USA.
If my math is correct, there is no way to have more than 4 solar panels in parallel due to wire gauge limitation on the solar panel junction box.
Question: What are the alternative solutions this problem with limitations on wire gauge and the inverter voltage.
Thank you,
Ben
NOCT
Pmax: 105W
Vmp: 30.8V
Imp: 3.42
Thank you,
Ben
