Hi guys,
I have read alot about the cost for the off grid solar battery system, I know the cost is base on the capacity of the battery and the life expentancy of the battery, then we calculate the cost for per kwh.
I have a question, do you guys take into consideration for the power that you use during the day time when you calculate the cost per kwh? for example, I use about 20 to 22 kwh per 24 hours, the battery supply about 10 kwh in the evening to the morning until the sun come out again.
During the day when the panels are producing I use around 12 kwh of the power. if I calculate these kwh into the cost per kwh, won't it bring down the total cost per kwh for off grid?
Thanks.
Thanks.
