Lead Acid vs Lithium Iron Phosphate ( LFP; LiFePO4 )
  • john p
    • Oct 2010
    • 738
    #31
    Mike90250 I wondered about that also ,And what fails first, the intergal BMS, or the cells ? Which ever fails, the wife will not like it with no lights.Thats why I bought individual cells . easy to replace one defective cell ,, just unbolt it
    • dave
      • Apr 2010
      • 17
      #32
      Here is a site State side that has 48v 100ah batteries http://www.lionev.com/battery_packs.html for $2320 which is about what John was quoting - Lifetime Warranty = Hope this helps.
      PS - The EV DIY car forum has a lot of info on LiFePO4 cells and compare them to LA - For low voltage the simple way is to find the cell which discharges the most and monitor this with a relay - apparently this is the way it is done with LA also. As far as balancing - as long as you use a LA charger the balancer is quite a simple device that discharges back all cells to the voltage of the lowest charged cell.
      • john p
        • Oct 2010
        • 738
        #33
        Sorry DAVE that is not quite right . attached is a picture of a 48v battery with BMS built in, as you can see it just lookes like "normal" truck or large deepcycle battery
          Originally posted by steveg
          Hi Mike,
          How many kWh for that?
          say it's 5kWh ...
          5000/51.2=98Ah at 70% DOD that's 140Ah LFP pack - I would recommend talking to this guy - mention Steve from New Zealand.
          Chris Zhang [sales02@chinabatterycenter.com]
          Should be US$2300 (+FGT+TAX) roughly for 100Ah 48V(16 cell) with a BMS built in.
          I have 48 of these cells in my setup.
          48V 400A bank, has 200A useable, so that's 9.6 kw, so I'd need 2 of those packs, and I'm not sure if there is a BMS in there already. With a lame website, it's not going to excite anyone.
          • john p
            • Oct 2010
            • 738
            #35
            Isaid in all the posts that THE BMS IN INSIDE THE BATTERY THE CIRCUIT BOARD IS JUST UNDER THE TOP OF THE BATTERY AND THE "REGULATORS " ARE ON EACH CELL.
            A long time ago their wb site was better it di show ALL THE BATTERIES
