24 or 48 volt battery bank
  • asdex
    • Nov 2013
    • 174
    Hi seems like a 48 volt battery bank would be best for my 2kw PV array but other than running an inverter how else do you utilize 48 volts? I run a 12 volt car stereo, 12 volt LED lighting, 12 volt USB charger for weather station and charging mp3 players etc and a 12 volt pump for the water header tank off my existing 12 volt battery bank. I have never seen the equivalents in 48 volts. Even the Danfoss fridge unit I am looking at is 12 and 24 volts.
    Do I use a dc-dc step-down converter?
    Thanks,
    • 5198
    Thanks,
    Seems like an efficient way to do this would be to build in a 48V to 12V DC-DC converter into
    or attached to each item. Distributing 48V will be efficient, and the output 12V regulated
    regardless of the battery voltage. Use a switch on the 48V side to avoid loss if not in use.
    You will not be running a very large converter in an inefficient, underutilized mode all the time.
    This is done in phone offices all the time. Bruce Roe
      I designed and built a 48V DC buss for a lighting trailer, where I used about 15 distributed DC-Dc converters, to power banks of 12V LEDs. To run enough copper to carry the total power at 12V, would have popped the tires. If you can stay with >90% DC-Dc converters, it will work, otherwise, you are better off getting a efficient 120VAC sine inverter to power conventional gear.
      Since we don't know what all the loads are, it's hard to be exact with advice.
      • asdex
        • Nov 2013
        • 174
        Hi, thanks for the advice. We don't use much power. The pump is 9amp 12v and runs for about 20 minutes every second day. The 5 LED lamps are 4 watt each I think. Not sure what a car stereo takes which we use about 4 or 5 hours a day.The other things are a laptop which I run from a 200watt inverter and an AA battery charger.
        It soulds like I can run all this ok from a dc-dc convertor. I also have a 1000w invertor which I use for small power tools like a jigsaw and renovator tool.
        I take it you would get as much power or have the same battery capacity with 800AH @12 volts as you do with 200AH @48 volts?
        Thanks,
          Thanks,
          Both have the same wh storage (9,600wh) but the 48V bank is more efficient because it's running less amps through the wires, and so there is less loss.
          • asdex
            • Nov 2013
            • 174
            The dc convertors for 48 volts to 12v and 24v I've seen to have an efficiency of 80% to 90% which isn't great. Plus the addition of an extra piece of electronics to rely on, I think I'll stick with 24 volts. I'n not concerned with voltage drop as everything is pretty close and I have plenty of 16mm cable (5 AWG I think.)
            Cheers,
              Cheers,
              If you go with 24 volts, you have limited your system size to 2000 watts with a 80 amp MPPT controller. To go any higher requires you to either convert to 48 volts, or add another controller.
                • 5198
                Cheers,
                The efficiency of converters with isolated input/output is less. If you have a simple
                load like an LED light, you you could a non isolating buck type converter which will
                greatly reduce losses. Typically the input and output will share a negative lead.
                Something like a computer input, better be isolated. Bruce Roe
                • asdex
                  • Nov 2013
                  • 174
                  Thanks for that information. I'll have a look at the buck convertors. I have decided to stick to 24 volt and if I ever need more panels, I'll get another controller. All the same I would feel if we can't live on 2 kw there is something wrong with our off-grid lifestyle. We have lived in a bus for two years and then on a yacht for two and a half with young family so I have a good idea of this sort of lifestyle.
                  Cheers,
                  • reed cundiff
                    • Nov 2013
                    • 98
                    There is supposed to be a good 48 V DC A/C that uses only 750 W. The Aussies are using Fujitsu DC A/Cs of various voltages. Primary reason for 48 V is probably less voltage/power loss. The voltage from our 6 panels (3 each in series) is about 90 V to TriStar MTTC-45. 1300 W is then only 14 amps and uses smaller cabling and much less power loss. Son designed and fabricated system. He is in commercial building/power plant solar with long cabling and the higher voltages is just part of his paradigm.
                    Reed and Elaine
                    • asdex
                      • Nov 2013
                      • 174
                      Reed and Elaine
                      Hi, thanks for your reply but we don't need an air conditioning unit. Our pv array voltage will be 73 volts and 1920 W which is 26 amps. The panels are 15 meters from the controller and batteries and I have 16mm sq 2 core cable (5 AWG). I have about 100 meters of this cable I got cheap so aren't too worried about voltage drop. I'm hoping the 24v bank will be fine.
                      Cheers,
