I bought a TED-5000 2 MTU system. MTU1 is working fine. Here is where the weird stuff starts. Let me say I have spent 2 hours on the phone with BOB from the TED5000 support family. Really a great guy. I had to cut our session short due to the fact I had to go to work. Let me start.
MTU2 is for a 7500KW solar system. It is setup the most common way with the power coming from the inverter into the breaker panel to a breaker. MTU2 gives no readings at all. MTU1 is set for Adjusted Load and MTU2 is set for generation. if you swap the CT's from MTU1 and put them down on the solar wires. No Readings. If you take the solar CT's and put them up on the top. They work fine. BOB told me my PLC was fine. I asked him if the size of the wire matter to the CT's and he said no. I am baffled. I used a voltage pen to make sure there was voltage coming through the two solar wires and there is. Thoughts?
This is a picture before the TED Install and you can see the red and black wires coming in from the inverter and going to the breaker in the lower left hand corner.
This shows the new 20 amp breaker I added and how both MTU's are wired to it. This breaker has an outlet I added strictly for the gateway.
Lastly here is a video I made that shows the whole setup. Any help would be greatly appreciated.
TED-5000_2_MTU_SYSTEM_HELP
