12v cell
  • 12v cell
    hi. i build my solar panel ,and i used 24 cell , who is 0.5v the one . all together they doinig 12v .
    my broblem is the other panels in my system they have out voltase 17v or 20v.
    i will have broplem if i connect my 12v panel in my system?
    is it going to work fine to give me more watts?
    thanks o lots
    mike
    ---Mod Note: I moved this post out of the Announcements thread where it did not belong.
    It is not going to work well with your other panels in either a parallel or series connection. In addition it will not be usable by itself for charging a 12V nominal battery of any type.
    A clear case of "Ready, Fire, Aim!"
    (If the output current of your panel is within 5% of the current of your other panels, you can can put it in series with those panel(s), as long as the device you are feeding will accept input power over a wide voltage range, i.e. MPPT input.)
