Will rain/moisture damage my AGM battery?
  • Will rain/moisture damage my AGM battery?
    Hi all,
    I've got a small experimental off grid system with a bunch of sensors to measure panel output, battery level, and usage through the inverter. Panel is 100W/20V, battery is a 34Ah AGM Sun xTender, and I've got a Sunsaver 12v charge controller.
    I recently got a second 34 Ah Sun xTender battery as a wedding present (glad we invited that couple), but it is going to make my battery/inverter set up a little bit bigger than I really want to have in my living room. So I want to move the battery/sensor set-up outside with the inverter inside the house.
    My biggest question before doing this is whether there will be any detrimental effects on the batteries from rain/weather? Will moisture damage the batteries; I'd specifically be worried about some kind of short or arc? I'm planning to store the batteries in a plastic bin or something like that, but do I need to completely seal it so that it won't get any moisture in there? Is moisture not a concern at all?
    Any suggestions you all have would be greatly appreciated.
    - Zack
    Direct rain that puddles on the top, is bad.
    Dirt/dust that collects in a film on the top (creating a conductive path from + to -) is bad.
    Bright light from the sun has UV which will degrade the plastic battery case.
      Also if the batteries are far from the inverter you will need to increase the size of the wiring to keep the voltage drop @ or below 2%.
