Hi I'm new and want to build an off grid system for fun / for power security and reducing fossil fuel consumption. I have a workshop area and a cabin. Currently sketching system diagrams and gathering parts.
I have an old 3000VA APC UPS which uses 48 volts of batteries.
I have purchased some reclaimed sealed lead acid batteries. They are 12V 38ah. I have.. 64 of them. Yes, sixty four. (I make that 29kw/h if I connect them all up)
I was thinking 4 banks of 16 making the required 48V. I could even do them in 2 separate lots.
Doesn't seem to be many budget charge controllers that output 48V so I was considering having something like one charge controller per battery. (or battery string) So each battery will be charged by 3 or 4 PV panels, via its own charge controller, and the batteries will be in series so that the 48V UPS/inverter can run from them. Can anyone see a reason why this wouldn't work?
I have some constant loads I would like to run via solar at least. A CCTV DVR system, PC and a couple of routers/ switches, plus some outdoor flood lighting. (80w mercury lamp, and some LED lamps)
There are some high wattage things here such as the air compressor but that will be staying on grid, along with stuff like the mig welder. I was even consideirng putting in two ring mains so I can swap appliances from grid to off-grid outlets according to state of battery / sunlight.
It is summer at the mo and I've not been using many power tools so in the last 2 or 3 days I have used about 6 to 10 units per 24h.
I have found a source of well priced 250W mono panels locally and have bought a couple to experiment with. I am planning to buy 12 or maybe 16 total. (3-4kwp)
I'm considering building a tracking frame for them as well, as a nice little project.
