battery cable size for 24 volt battery bank 4x6v batteries
  • bahamasolarnoob
    • Apr 2013
    • 60
    Goodafternoon, what size battery cable is best used in my situation to wire 4x 6v trojan golfcart batteries in series? (will make it 8 batteries this year)
    I have 4x240V panels, 24 V 1500 w inverter, 60 amp MPPT xantrex/schneider
    On youtube I see 2 gauge and sometimes 4 gauge. In our local Carquest I see complete battery cables 12" 4 ga. for $11, another store is able to cut and crimp 2 ga. cables for $28 each.
    If you need more info let me know.
    It is all based on peak load current and cable length to maintain 2% of less voltage drops. So until you can give us those details no one can help you. Forget what you have seen on You R Screwed Tube.
    But I can get you close making some assumptions.
    Fist assumption is your panels are wired in a 2 x 2 configuration yielding 72 volts @ 14 amps on a length of cable of no more than 10 meters one-way cable distance. That would require a minimum of #12 AWG stranded copper between the panels and CC.
    The cable between the CC and battery post of no one-way length longer than 3 meters running 24 volts @ 40 amps will require to be no smaller than # 8 AWG stranded copper.
    The cable between your battery and inverter at no one-way length longer than 3 meter running 24 volts @ 65 amps will need to be no smaller than 6 AWG stranded copper wire.
    Those are the minimum sizes required to be safe and meet 2% or less voltage drop between devices. All totaled up about 5% loss on all cables. If you want to go larger you can but at extra expense.
    • bahamasolarnoob
      • Apr 2013
      • 60
      Hi Sunking how have you been. Ok, that is good to know, your assumptions are spot on. I will change some wiring on my plan.
      But what I meant to ask was the proper gauge size of the 12 inch " jumper cables" between the
      6 volt batteries in series. They sell 4 gauge and 2 gauge.
        Either will work for you. If the added cost for 2 AWG over 4 AWG is not important to you, go with 2 AWG as it handles more current with less loss.
        • mapmaker
          • Aug 2012
          • 353
          <snip>
          My advice is to make the battery cables (between batteries and from battery to inverter) thicker than #6. If you have anything with a startup surge (such as a water pump, refrigerator, power tool, etc) you will exceed the 1500 watt rating of your inverter for a moment, and the resistance of the battery cables may prevent the appliance or tool from starting.
          You didn't mention what brand or model of inverter you are using... I have never seen an inverter that did not include a recommended cable and fuse size for the DC input.
          --mapmaker
            And if you take note, most recommend too small of a cable based solely on minimum cable size to safely handle the current in Free Air from NEC tables. For low voltage we use maximum voltage drop of 2% or less. The start up surges if 2% or less is not a real issue. 2% of 24 volts = .48 volts. If we double the current momentarily the voltage loss is .96 volts or 4%.
            However with that said I have no issue using a larger cable than required if your economics can afford it. As stated I said 2% or less, and 2% can get expensive on long runs.
            • bahamasolarnoob
              • Apr 2013
              • 60
              Ok thanks.
                Bob if it makes things easier for you tooling and installation wise, just use 2 AWG from the battery inter-cell connections to the inverter. Personally I do not suggest using 2 AWG from the panels to the controllers because of the expense. But if you can afford it and the equipment can actually terminate that large of a cable goferit.
                What I gave you is minimum requirements to meet 2% of less voltage loss.
                Good Luck
