Just throwing around some dream ideas if I had the cash and resources....but is my math right?
I would be running 2,400 watts an hour, for 12 hours a day...so my need is 28,800 watt hours per day right?
I would want a 48v bank...which would require 1,532 amp hours @ 60f lowest temp and an assumed 50% discharge.
My numbers come out to be 52 AGM batteries rated at 12v and 125AH each
4 strings of 13
each string wired in series to give 1,625AH
and each string connected in parallel to increase the voltage to 48v
Is this right, it seems like a whole lot?
Now on too calculating the amount of 250w solar panels mounted to as many needed dual axis sun trackers??
4 strings of 13
