Originally posted by LucMan
View Post
solar collector in garden / possibly / unsure of pipe insulation
[SIGPIC][/SIGPIC] -
Originally posted by LucMan View PostPex ratings are 80 psi at 200 F. 100psi at 180 F extrapolating you get 240F at 40 psi. Selecting the correct T&P valves is extremely important.
If you connect to the collectors with a minimum of 8 ft of copper tubing you will be ok. There would have to be multiple failures in the system safety controls before the pex could fail.
As an example, consider an extrapolation of metal shear strength versus temperature. There is a really sharp bend in the curve near the melting point.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Thank you again to everyone for your recommendations.
- CPVC or copper - but not PEX
- Allowing for thermal expansion
- Ensuring about safety
- Hire a professional for these.
However, I'm still hoping for guidance on the single initial question whether I should run with this or not? Based on the anticipated potential heat loss from the insulated pipes? I'm not looking for precise calculations, just educated ball park figures. Would it be 5%, 10% 30% heat loss? Just enough heat loss advice to pursue it, or kill it.
A = Styrofoam or cold cell foam
B = Leak detection
C = Radiant insulation, foam layer
D = 300mm PVC drainage pipe
F = Gravel trench fillComment
Originally posted by oemodm View PostThank you again to everyone for your recommendations.
[ATTACH=CONFIG]4228[/ATTACH]
B = Leak detection
Finally, I'm having a hard time imagining a way to make this anywhere near cost effective. This may be gross overkill in the insulation dept.Comment
take a look at what was used in the Solar Shed http://www.builditsolar.com/Projects.../solarshed.htm
maybe you will get some ideas of what works for othersPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Here is a link to Armacell insulation, available in wall thickness from 3/8" - 1". (Losses can be calculated from the spec sheet. )
There will be losses no matter what insulation you use. The question is how much money are you willing to spend on reducing those losses.
https://www.google.com/url?sa=t&sour...Y00vmXbmJtzpjw
The pipe of your choice can be run inside 4" nonperforated drainage pipe insulated with armacell, glued at all butt joints.
Insulation Wall thickness over 1" in my opinion would be a waste of money.Comment
