I am trying to build my own solar panel. I realize that these are best for a learning experience. But I am apparently doing something wrong when I link the cells together and I am not sure what. I purchased 40 6x6 solar cells. But when I solder the cells together and attempt to test it with my Multimeter I am not getting a voltage reading. I have them linked together from + to - so I am really at a loss. If anyone could please tell me what I may be doing wrong.
I'm new and need help.
It's also entirely likely the cells you bought, are duds
Or you BBQ'd the metal layers off while soldering
Or you shorted something
With a virgin cell, you should be able to measure 0.5V in good light.
Switch the meter to amps, and you should measure at least 1A in full sun.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
