Net Metering to Distributed Generation Program.
  • jschner
    • 28
    Currently I'm on a net metering plan with my city and if I generate more than I use each month I do not pay anything for electricity except the service fee. Any surplus is credited as the city only watches for forward movement on the meter. At the systems anniversary turn on date, the local utility can cut a check for surplus power if any. I have not had any surplus so I have not received a check.
    So now my city has adopted the Distributed Generation Program with the Distributed Generation Rate. Here is a link to the program as given to the City Council. http://www.cityofshastalake.org/Arch...wFile/Item/235 Scroll down to page 30 of the document.
    So if I am reading that correctly. My solar now only produces $0.0865 per kW instead of the full rate of $.1404? In other words they reduced my solar benefit by nearly 38%
    Last year I used 10426kW and generated 9937kW(production meter) with my 5.72kW system. Paid roughly $68 for electricity.
    If I do the same this year, under this DG program it will be 10426*.14 - 9937*.0865 = $600
    Unless I'm reading this wrong, it looks like I will be back to paying $50 a month on average for electricity.
    It is page 30 by the way - I almost didn't bother to go through the whole thing.
    They screwed you nicely and played with words to make it sound fair. As the utility is city owned they want the profit of your pre solar bill. The less you use the more they lose.
    Totally unfair and dreamed up by some real dunces. Grid tied users should pay for distribution system use but that should be a nominal amount.
    Next election you need to remember that these clowns are not your friends- they are stealing from you.
    • silversaver
      • 1390
      The city is paying you $0.0865 per kWh. I'm not sure how much money you spent on your 5.72kW solar and how much incentive you received from city, I don't think you can benefit anything from your solar system since your cost to generate each kWh might be higher. That means is the end of net metering at your location. When city owns the utilities, that's really bad....
      PS. You forgot about your basic meter fee and public benefit 2.85%...... russ is right, they play nice wording sounds like they credit you more than net metering...
      "Net Compensation Rate of $0.0341 vs. Distributed Generation Rate of $0.0865"
      "No value for Renewable Energy Credits vs. Rewards for Renewable Energy Credits"
      "Degrades Public Benefit Revenues vs. Preserves Public Benefit Revenues"
      "Promotes rate subsidies vs. Preserves Cost of Service"
      Only thirteen (13) existing customer-owned generators? must be a small town where city own utilities......
      • jschner
        • 28
        Yes, small town of about 10,000. And yep getting screwed big time!
        • raydias
          • Mar 2011
          • 46
          Looks like you have a few options
          - add more solar to reduce what you get from the utility overall
          - run the numbers and see when you use city power and see if you can reduce that by either improving efficiency or shifty loads to times when you produce excess
          - add a battery system to minimize power sent to the utility as well as power from the utility
          very short sited since they save in transmission upgrades and in purchasing power by getting your excess and sending it to the neighbor(s)
          You might also want to see if the PUC has anything to say about this. Finally you can complain to your Representative at the state capital see. i can see more utilities (Government run) trying to go down this route to discourage solar.
          --Ray
          8xSV-X-195-LV - 22.80 Voc - 18.30 Vmp - 10.66 Imp - 11.55 Isc
          2xUL Solar 85w - 21.9 Voc - 17.9 Vmp - 4.84 Imp - 5.17 Isc
          1xUL Solar 120w - 21.9 Voc - 18.1 Vmp - 6.6 Imp - 6.8 Isc
          7xHF 15w - 23.57 Voc - 17.5 Vmp - 0.86 Imp - 1.15 Isc
          MorningStar MPPT 60 Charge Controller
          Midnite Classic 150 Charge Controller
          700ah used Gel batteries
          Xantrex PROWatts 600 PSW Inverter
          HF 1000/2000 MSW Watt Inverter
            The more he produces the more he loses.
            • raydias
              • Mar 2011
              • 46
              From what I saw the more he produces the more it will offset the consumption
              From the example provided in the City meeting link
              City Power 300 KW x Tier 1 rate 0.1404 = $42.12 + service charge of $13.50 and Public benefit $1.59 (2.85) = 57.21
              Self produced 500 KW x 0.0865 = 45.85
              City $57.21 - Self $45.85 = $11.36 to the city
              Now if he produced more
              Self produced 700 KW x 0.0865 = $60.55
              City $57.21 - Self $60.55 = $3.34 credit
              So he would not be loosing? and if he can reduce the city consumption more the better the numbers.
              This is from the example provided on page 17 that compares the old structure to the new. i wouldn't be surprised if they charged a service fee for the new meter as well.... But in the end adding more solar would reduce or eliminate the city bill based on the example provided.
              --Ray
              • wanabefree
                • Jan 2014
                • 81
                In California doesnt the PUC have jurisdiction over all Utilities
                I think I would contact the PUC and see where the are in all of this. I was of the opinion that in California all POC's were required to offer net metering under the State mandated Law. I think this is an end around to try and circumvent the law and some local politicians trying to act like they are in control.
                  • 14925
                  Maybe, maybe not. AB 327 was aimed primarily at the big 3 investor owned utilities SCE, PG & E and SDG & E. The PUC, oversees those and the smaller ones, but municipal and other smaller utilites are treated differently in more than a few respects. Eventually, they all follow PUC mandates, but those mandates do not apply equally or to all necessarily.
                  • silversaver
                    • 1390
                    russ is right.
                    raydias, you need to work on the math part and read. When POCO only offer you $0.0865 per kWh generated, putting more solar is plain stupid. It is 2 meter systems. You sell ALL solar generated and buy ALL from POCO. It isn't net metering.
                    • raydias
                      • Mar 2011
                      • 46
                      Originally posted by silversaver
                      russ is right.
                      please explain how my math is wrong, I never mentioned netmetering?
                      you might want to review the document and example provided and clarify?
                      if he gets 300kw from the city and produces 500kw he has a charge. If he produces 700kw instead he gets a credit. looks straight forward to me. Now does installing the extra solar to get to that level make financial sense? that's a different question.
                      So again I am not basing my numbers on netmetering but on the 2 meter setup that the example outlines.
                      --Ray
                        That was the only question - it is rather silly to install more solar when you get so little for the surplus and you have no idea when the clowns are going to change the rules again.
                        • silversaver
                          • 1390
                          Now, this sounds like politician. Completely worthless.
                          • raydias
                            • Mar 2011
                            • 46
                            Ah yes why have facts get in the way or provide actual data to backup your statement. Easier to be a jerk about it.
                            Now I know who to ignore.
                            --Ray
                              Two Jewish tailors, Adam and David, with stores side by side are talking in front of their shops about business. Adam is frustrated because business is so slow, and David is happy and extremely busy.
                              Adam charges $400 for a tailored men's suit and it cost him $350 to make a suit. David on the other hand charges $300 for the same suit, but cost him the same $350 to make it. Naturally David is selling suits faster than he can make them. Adam knows the economics and ask David how he can stay in business selling for a loss. David happily replies: I make up for it in volume.
