Needs some advice
  • Willdog
    • 12
    Needs some advice
    Hi all,
    I am building off grid solar systems that consist of:
    2 - 100 watt panels
    1 – 12 volt, 30 AMP battery charger- Max solar input 450watt
    1 - Pure sine 2200 power inverter – 4400 peak
    8- 35AH seal batteries
    Can anyone tell me what will be my back feed breaker AMPS?
    Maximum allowed PV breaker?
    Do I need a service panel or just a disconnect switch?
  • Shockah
    • Nov 2013
    • 569
    Originally posted by Willdog
    Hi all,
    2 - 100 watt panels
    Mismatched combo.
    What are you powering?
    2200w/4400w is too large for any 12v system.
    8 batteries? All in parallel?
    You got changes to make before you worry about ONLY the breaker.
      Not going to work out very good. About as soon as you put a 100 to 200 wat load on th einverter it will trip off-line from under voltage as you battery grunts and groans.
      200 watt panels with MPPT need a battery capacity of at least 130 AH and you have a 35 AH battery so will over charge and gast the battery severly
      A 200 watt 12 volt inverter is plain silly. It takes at least a 1200 AH battery to drive it up to 2000 watts, and a 1200 AH 12 volt battery needs 2000 watts of panels to maintain them. You have a 35 AH battery only capable of driving a 60 watt inverter.
      You pretty much mismatched everything possible. Based on your 200 watt panel using the minimum 130 AH battery will support a 200 watt inverter. Note Panel wattage= roughly inverter wattage.
      • Shockah
        • Nov 2013
        • 569
        200 watt panels with MPPT need a battery capacity of at least 130 AH and you have a 35 AH battery ............
        Actually Sunking,
        the good news is he has 280ah battery-pack...
        the bad news is that it is constructed from 8x 35ah batteries in Parallel... which negates the good news.
          Originally posted by Shockah
          Actually Sunking,
          My bad did not catch that. Yeah insane using parallel batteries.
          But even at 280 AH is not going to drive a 2000/4000 watt 12 volt inverter so it is a moot point. 200 watt panel 280 AH battery means at best a 400-500 watt inverter.
          • Willdog
            • 12
            I am here to learn that is why I asked the questions
            Mismatched combo.
            I am planning on running a pool filter and power tools. This is for outside use only. I was planning to connect the batteries in series to increase the voltage. I went with a 2220-watt inverter for later expansion.
            I appreciate your comments, help me understand
            • Shockah
              • Nov 2013
              • 569
              You must determine watt-hours needed for filter & tools before building a Solar/Battery System...
              and you will realize you need a much bigger system than you imagined.
              8 batteries in series will be 96vdc @ 35ah... you're not going to accomplish anything with that configuration.
              What is the input voltage of the 2200/4400 inverter? 12vdc? 24vdc?
              • Willdog
                • 12
                OK, I do have a 600-watt inverter on hand and two more 100 watt panels on the way.
                • Willdog
                  • 12
                  Input voltage of the inverter is 10 – 15 vdc. Model APS2200-12, output 115 vac.
                  • Willdog
                    • 12
                    Then parallel is better than wiring the batteries in series?
                    • Willdog
                      • 12
                      Go it
                      Thnaks
                      In series is more voltage.
                      In Parallel is more amp hours
                      Thanks for that
                      • Willdog
                        • 12
                        • Willdog
                          • 12
                          • Willdog
                            • 12
                            Actually Sunking,
                            Thanks for that
                            • Shockah
                              • Nov 2013
                              • 569
                              It's all in the Stickies...
                              4400watts / 12volts = 367amps.
                              You'd need a really thick cable from the battery to the inverter to move 367amps safely.
                              Read this.
                              Thanks for that
                              Correct... but don't assume you are good with 8 batteries in parallel.
                              Read this and this.
                              Steps in a better direction...
                              But before you spend more money, read this.
