Hello fellow off-griders,
I managed through a fit of distraction to plug a 6Kva generator into a house socket without disconnecting my Berel electronics 24v 60A EC3000 inverter.
The fuse on the inverters positive battery connection blew instantly. Having disconnected the generator and (yes) foolishly wired across the blown fuse, as I didn't have a replacement at hand, I turned the inverter back on and this time blew the fuse on the negative battery connection. Having finally found replacement fuses, not an easy thing in the boonies of Spain, they blew as well.
I did request help from Berel (a German company) but received no reply, maybe they don't speak English.
So the question to anyone technically minded or indeed qualified as an electrical engineer is, what is the most probable damage that I caused?
I had to replace the inverter, as the house is off grid but I am keen to repair the blown inverter to act as a stand-by just in case.
If I haven't provided enough information, I'll be more than pleased to provide whatever I can.
Yours hopefully
Confused
Yours hopefully
Confused
