Recently my batteries where giving less backup. I checked up few parameters, and found out few facts about my system. And I am really in confused state. Pls guide me.
I am having 2 Exide c10 150AH flooded lead acid batteries connected series (24V inverter). Now initially when I checked specific gravity of cells(at full charge condition), it showed around 1.2, but 2 cells (1 each in 2 batteries) showed 1.15.Which is way below manufacturer specification of 1.250. Immediately I took it my dealer, and he put them on charger. Even after 24 hrs of charging batteries couldn't go beyond 15V each ( manufacturer equalization voltage is 16.5v). I checked his changing current,which was 4.5 A, and was way below recommended charging current for batteries ( 10 % AH capacity). SO is that the reason my batteries didn't go beyond 15v??
Now dealer is sending batteries back to manufacturer.
Coming to my inverter charging part: I am having MPPT charge controller based inverter. I did note there is a difference of 0.5 V in what display shows and what actually battery voltage is. (display volt = battery volt+0.5) i.e display voltage is higher!! My inverter has full battery cut off at 28.5V, but actually it charges only 28V. And inverter logic switches load from mains to solar, immediately after it reaches full charge state. So my inverter never maintains floating state for battery!! Also same applies to mains reconnect voltage which 23V, which way too low as actual battery voltage is 22.5V.
What to do guys??
Will getting a separate battery charger / equalizer , and charging occasionally like once a weak, will help??
MY battery is EXIDE flooded lead acid type and inverter is 1000VA MRO TEK inverter.
Urgent help needed pls
What to do guys??
