No Sir that is not what I am saying.
If I understood you correctly it sounds like you plan to take batteries off line, or disconnect and rotating batteries in and out of circuit. If that is what you intend to do you are playing with fire. In other words let's say for example you are going to use two 12 volt batteries. One off-line, and the other on-line. When you connect two batteries together in parallel that are at different state of charge, you will have massive amounts of equalizing current flowing between the two batteries. The battery with a higher state of charge will try to equalize and pull up the lower state of charge battery. With the size of batteries you are using that can be up in the thousands of amps, and if there is no over current protection devices (like fuses) on each battery there is no way to break the connection and the wiring will act as a fuse by bursting into flames and melting the copper wire. It is bad enough if that happens on dry land, but really bad on boat and planes.
So please don't get offended, I just care about folks safety.
On a different subject what are you going with 12 volts? Why not 24 or 48?
