Pool pump for heating
  • Pool pump for heating
    Hi all. I am completely new to this forum so sorry if this has been covered somewhere.
    I have a house in cyprus with a pool which in the summer is fine but out of season it's to cold to use.
    I have been pondering the idea of heating by solar and my idea is to pump the water from the pool onto the top of my pergola (about 3.5 might) then use black hose as a collector and return to the pool.
    I do not want to spend a fortune but would like to know what kind of pump to use and what size cell I would require. I don't have to shift the water to fast but just continually whist the sun shines.
    Could be that the whole thing is not feasible but I am sure someone on here will know.
    Thanks in advance.
    Dennis.
    Look at builditsolar.com
    Lots of ideas there about pool heating.
    Yes your idea will work but will need a fair amount of pipe and area to work.
      Thanks in advance.
      Dennis.
      Welcome to Solar Panel Talk, Dennis!
      Well, the general idea of solar thermal heating is a good one, and the details and practicality of the design will vary depending on what the outside air temperature will be (whether you will need to put a transparent cover over the coils to reduce heat loss, for example.)
      As for the pump, to get started at least you will probably find it easiest to use a mains powered small pump that is rated to handle the chemicals routinely used in swimming pool water.
      If the idea works out, you may want to consider solar PV power for the pump, letting it run only while the coils are producing heat.
      You will need to shut the flow off when the coil temperature is to few degrees above the pool temperature.
      If you already use a circulating pump for filter, etc. then electrically operated diversion valves may be all that you need.
      If the temperature will get below freezing, you will need a way to drain the system, either automatically or when the pool season is over.
        Here is a link that may be of assistance - good information in some detail.
        Black pipe coil pool heater http://rimstar.org/renewnrg/solar_po...ter_diy_fp.htm
        Russ
          Thank you for that looks possible
            Hi Denek
            There are different categories of Pool Heating that you can use like CS series, Force series,DHP-R Series. These series are for both commercial and domestic use. This will surely help you out. But before going further I will suggest you to concern a company that will tell you which series is more suitable for your home according to your requirements.
