We have just had a 300 litre heat store installed, with heat input from solar thermal panels and a log burning stove with back burner. Output is hot tap water via a heat exchange and a radiator circuit.
We have gone to a lot of trouble to insulate all pipes in the house, both hot and cold, but had a specialist contractor install the log burner and heat store (solar panels had been previously installed).
During the installation of the heat store, I spotted the main cold feed in and hot feed out were about 5mm (1/4 inch) apart and asked how he was going to stop thermal bridging, then it transpired he was not going to insulate anything in the cylinder cupboard. Best I could achieve, and this was begrudgingly done, was to get him to move the hot feed away from the cold feed in, saying that if he was not going to insulate I would have to, so could he please allow me space around every pipe to do so.
So, none of the pipes in the area of the thermal store are insulated and pipes are laid in for the convenience of installation, not insulation that will now be awkward for me to do.
To me all things eco and solar should be insulated within an inch of their life and this is something I should expect from this sort of installation.
For your info, I am in the UK just north of London, so climate is not like California…
Am I wrong to think in the area of the tank, at very least the hot should be insulated, but in ideally both hot and cold ?
