Hi guys,
Just returned from Orlando, The battery on the small pond solar system seem need EQ. My helper told me last week after a cloudy day the inverter trip off in the morning when she come to work, I told her to turn off the inverter and plug the pump to the house system. after about 4 days bright sun without any consumption the battery still not fully charged, actually the SG reading on 3 of the 4 batteries are below 1,200. I think I need to do thoroughly EQ on these batteries to see if any different.
My question is, if I don't want to use the generator or the grid (actually I have problem to use the grid as the inverter in this system doesn't have a charger, and the new charge I got I don't think it have the EQ feature).
Can I charge the batteries in one day with a charge controller with higher voltage and continue the next day without using the batteries? I can separate the two bank and charge one bank at a time and the other another time. if the EQ can't finished one day, can I continue the next day? with out discharge it or I have to make it run through without stop?
Thank you.
Thank you.
