sizing up mppt controller againts panels
  • sizing up mppt controller againts panels
    Hello all,
    is there a formula on how to get the correct mppt controller for panels like these?
    e.g 250watts
    Maximum Power (Pmax): 120W
    Voltage at Pmax (Vmp): 17.4V
    Current at Pmax (Imp): 6.91A
    Open-circuit voltage (Voc): 22.0V
    Short circuit current (Isc): 7.28A
    Thanks sa mag susuggest or mag help
    If it is a real MPPT controller Amps = Watts / Battery Voltage.
      Originally posted by sunnyday View Post
      Hello all,
      e.g 250watts
      Hello again Sunking, i dont understand. so there are others that are not so 'real' MPPT's controllers out there?
      also i wanted to connect 2 250w panels with same specs as above. should it be parallel with 24v of batteries?
      thanks sir
        there are many "knockoff" boxes from disreputable mfrs, that have a couple o junk parts inside, a blinky LED, and a sticker on the outside that says MPPT. junk inside.
          thanks sir
          Whatever battery voltage you want makes no difference. 500 watts / 12 volts = 41.6 amps, or 500 watts / 24 volts = 20.8 amps. Take your pick.
          You run panel voltage as high as possible with MPPT, so in your example they would be in series regardless of battery of voltage assuming you choose a MPPT with a high enough Voc input. There are controllers that can input up to 600 volts and run a 12 volt battery.
            is this the spec i should be looking for?
            Max. PV input power=12V 130W; 24V 260W
            Thank you for the replies
              or this?
              Max PV input power 12V 520W; 24V 1040W
                or this?
                No that only tells us the controller is 40 amps. What is the Voc input of the controller?
                  is this the correct info?
                  Max.PV open circuit voltage = 100VDC
                  http://www.epsolarpv.com/en/index.ph.../444/am_id/136
                  that link is the actual product that i am trying to consider as its the only one available right now besides their 60a which is twice the price.
                    I am not familiar with this product but I see a big RED FLAG.
                    Tracer is an advanced Maximum Power Point Tracking MPPT controller. ·4-Stage charge with PWM output
                    Which is it? MPPT OR PWM?
                      well yes ofcourse its made in china . but closest that i can get as shipping isnt really an option. (local gov't taxes us with twice the price of the bought items)
                      i have seen a lot of guys using this locally so im assuming they ok. they confirmed its mppt too.
                        Per someone in this thread , http://www.solarpaneltalk.com/showth...ge-Controllers , MPPT tech is on the panel side of the CC, but they still send power to the batteries via PWM (except when in bulk mode).
                        Someone else on that other thread has a Tracer 4210 ; He said it is good, but he is upgrading to an outback because he wants more features.
                          I had a tracer 3215. I recently upgraded to a midnite classic 150. I run 3 panels in series, and saw an improvement, but it wasn't mind blowing how much better it did. The tracer works, it is very slow in tracking, but it does work and finds the max power point. The features of the midnite are just so much better, and worth every dollar.
