Hi to all...
I need to find some circuit breakers for my system but the only ones I can find are thermally operated that is they seem to trip when they get warm not when the circuit goes over current (or stays way under the rated current of the breaker)...
I have 8 panels equating to 1.96 KW (8x245W) with maximum current flow of around 50A at 24 Volts (highest current flow measured to date is 48A)...
These go through a 60A circuit breaker (http://www.ebay.co.uk/itm/3604997338...84.m1439.l2649 ) and then into my charge controller which is a 60A MPPT and then through another 60A breaker same as before on to a 24V 900Ah gel traction battery...
I then have my load connected to the batteries through a similar 40A breaker (load never exceeds 30A).
So what seems to happen is on a really sunny day everything starts fine until the incoming current gets near to the 40A mark at which point the breakers start tripping even though I am 100% positive the Amps are no where near the rated breaker amperage. I think the breakers contain a bimetallic strip so when they get warm they trip, not really a great design but I like the breakers because they allow me to isolate parts of my circuit to perform changes etc but also give protection from shorts.
My question is what alternatives are there that do what I need that aren't over expensive?
