so I thought I'd disconnect all my batteries today...
  • FunGas
    • Aug 2012
    • 99
    Let them sit unloaded for a while, test the Voltages on & off loads (I use a motor as a load) see which batteries to remove, etc, etc.
    I had eight 12V 7AH Sealed Lead Acid in parallel, all but one were secondhand, from old computer UPS's.
    They're all wired with same-length connectors to the MPPT controllers battery output bus. (like it describes [url=http://www.smartgauge.co.uk/batt_con.htmlhere[/url] in section 3)
    Anyway, there is a small Voltmeter permanently connected across the whole stack, telling me the average Voltage, which read 12.7
    So, I thought this was a bit strange, seeing as I hadn't used them for a month or so and that the panel on the other wall, connected between the solar panel and charge controller read 15V 5A.
    Where's this 75 Watts going I wondered?
    So I began to pull all the red cables off the terminal posts, came to a pair of batteries and thought f**! that, they're hot.
    Yes, the pair I removed took over an hour to cool down, one was beginning to bulge as I've seen so very often.
    There's a lesson here somewhere - OK, I know mixing old and new (or weak and strong) is not a good idea, but never realised how hot they could get.
    Actually, we had a power cut this morning and I was just after another battery to replace my internet modem's UPS inside, but that gave me a good excuse to do this "test".
    I will replace the wooden board they are sitting on for a plastic tray, in case I get any leakage from splitting, which would not be good for whatever is on the bench below...
    Dem
    I'd put that battery bank on something fireproof, like a concrete floor. As you have observed, you are working with some powerful stuff.
    And I'm not sure where you obtained the 75w figure ?
    average Voltage, which read 12.7 So, I thought this was a bit strange, seeing as I hadn't used them for a month or so and that the panel on the other wall, connected between the solar panel and charge controller read 15V 5A. Where's this 75 Watts going I wondered?
      Last I looked 15 x 5 = 75. Some of that may have been going into chemical reactions, but all of it was going into the batteries one way or another.
        my bad, I didn't see the 5A, just saw it as 15.5v & 12.7v
        you have to use either a pair of calibrated meters, or use the same meter in 2 locations.
        if the batteries were charging @ 5A, they were not idle, so voltage testing is invalid.
          What you found is a common problem with AGM batteries called Thermal Runaway. This is another reason you should not parallel batteries.
          • FunGas
            • Aug 2012
            • 99
            There's a good description of Thermal Runaway here.
            My stack are all close-packed, probably leading to this condition.
            I always thought the bulging in duff batteries was the oxidisation of the plates physically taking up too much room...
            Mike - here's where the solar panel cable enters the workshop, the cable you can see on the top left goes to the charge controller.
            Dem
            • PNjunction
              • 2179
              Heh, you bet. It's called starting out on the wrong foot.
              Just get a NEW single 12v agm, somewhere in the 56ah range. Instead of trying to keep 48 2v cells in balance, from trash batteries to start with, you'll only be dealing with 6 cells totally under your care from the start.
              Used cells in a solar project are like using somebody else's toothbrush.
                First lesson to learn is do not parallel batteries.
