As regarding NiMh and Solar Panels I have some questions in my mind and I can not find the answer by myself, and I had browsing the web from about 6-8 moths now for nimh+solar panels comobo, circuits, devices, but I haven’t found the answers to my questions.
If you know the answer, please have patience to write a reply…
Thank You in advance!
Using Solar Panel, NiMh battery and PCB from Li-Ion/LiPo
As I know, Li-Ion, Li-Po, LeadAcid, PbGell, charging relays/charging controllers are using Voltage to Stop the battery from overcharging. For example the Auto Relay for the car battery and the Protection Circuit from the Li-Ion/LiPo.
But, on the NiMh I saw that the controlling the charging and overcharging, is more difficult as the relay/charging controller/charger is NOT using the Voltage but, instead is using one or a combination of these:
- Time Control
- Temperature control
- Minus Delta V -Δ v
- Microprocesor for different stages of charging, discharging etc.
Note: *In all the charging process I have left out the charging rate as I don’t know how to calculate it or what the parameters for various chemistry are.
I have these question in my mind am curious about:
1) (A & B & C)
What will happen If the Voltage will be used to stop the charging and potect the NiMh being overcharged instead of time, Minus Delta V -Δ v, or temperature control?
Are they kind of / in some degree protected?
1.A)
Using 3 Nimh in series with a Li-Ion Protection circuit, On small solar panel, they will slowly absorb power and will be overcharged and damaged or will be like trickle charging? What about on a bigger solar panel?
A Li-Po/Li-Ion protection circuit will be better than nothing? Will this work, or will be this like a “semi-protection”, or will not work at all?
The nimh will be overcharged in this combination if will be left in the sun long periods of time and no consumer?
How it will perform on a solar panel rated at 5-6V with output of 110mAh-400 mAh (0.6-1.8 Watt), a Zener diode IN5819, the Li-Ion Protection circuit on a 3 AAA NiMh 1.2V @ 500 mAh cells in series ( 1.2V x3 = 3.6V @ 500 mAh, 1.8 W)?
But how about if the solar panel will be 4.8V and 10 mAh?
1.B)
What will happen if I will use 3 NiMh Cells in series with a Li-Ion Protection circuit when the charging current can be from 10 mAh to 10Ah? As the protection circuit will cut of at 4.2 Volt, will the NiMh be overcharged? Are they kind of / in some degree protected?
I can have a pack with 3 cells of 1.2V connected in series, protected by a LiIon/LiPo , and various power sources like:
- Transformer from the grid 5V 10 Ah
- Transformer from the grid 5V 550 mAh
- Transformer from the grid 5V 1A
- Transformer from the grid 5V 2A
- Usb devices like a Laptop, Pc, etc. 5V, 500-1000 mAh
- Usb Chargers with output of 5V 150 mAh
- Various solar panels of 5V-6V @5mAh, 10mAh, 30mAh, 100mAh, 900mAh, or even 6000 mAh (6Ah)
1.C)
If there is a need to charge and discharge NiMh individually and not in pair (2,3,4 pieces in series) Can they be protected in this way?
The power supply can be a Solar Panel+diode which charge more NiMh’s that are connected in parallel, and left there for an undefined period of time, with various size like AA, AAA, C, D, ranging from 100 to 8000 mAh and there could be a protection circuit on every one cell of NiMh, which will disconnect the current within the range of 0.7V-1.4V for preventing the over-discharge and over-charging.
I have found some circuit which disconnects the nimh battery when it reaches at 0.7V somewhere on the internet but I can’t remember or find it again anymore, as regarding the 1.4V limit maybe something like Zener diode will help.
Thoughts:
-The characteristic of one cell of NiMh is rated at 1.2V.
But… in reality while being charged the voltage grows up and up and up then will drop a little bit (this is the mechanism of –delta V method). As I have seen the most of fully charged NiMh have a voltage of 1.4 or 1.5 Volt right out of the grid charger regardless it is a fast, smart, overnight charger, but the fully charged voltage may vary a little bit depending of manufacturer or the cell itself. As regarding discharging they could be fully discharged and they will be harmed by deep-discharging, but will not be so severe as in Li-Ion.
-The characteristic of one cellphone Li-Ion/Li-Po cell is rated at 3.7V.
But… in reality while is empty it is at 3.0V and while full charged is at 4.2 V. The Cellphone battery has an Protection circuit on it for protecting the battery which is cutting the current between the limit of 3.0V and 4.2V.
Now, If I have 3 NiMh (AAA, AA, C or D) connected in series I will have: 1.2V x 3 = 3.6V
The same rated voltage like a LiPo/Li-Ion!
While 3 NiMh fully charged connected in series is about
1.4V x 3 = 4.2 V
The same Voltage like a fully charged LiPo!
Figure 1
Figure 2
Figure 3
2) (A & B)
2.A)
How come that all of the Ni-mh solar charger are with NO overcharging circuit? Browsing the web after nimh solar charger I have found a big diversity of NiMh+solar combo (with warious cell number as 1,2,3,4,6 or 8 etc. with size of nimh battery AAA, AA, C, D, different solar panels with different rated power etc.) but I have NOT seen a overcharge protection circuit on them, why? If I will left the device in sun with no consumer for a year for example, the NiMh battery will be overcharged and damaged this way, right?
2.B)
Even more, I have not seen a device with an “anti-full discharge protection circuit” for preventing reverse polarity or the NiMh battery life. As I understand the NiMh battery life will be longer and will have more recharge cicles if it will be not discharged at the full capacity, and some juice will be lefted in.
Examples:
- Varta NiMh Solar Charger, no Overcharge Ciruit
- Raspberry-pi SolarPowered NiMh, no Overcharge Circuit
- Various Home Made / Do it yourself Nimh solar chargers
- Various Solar Garden Lamps
(I understand that on the solar garden lamps, there has to be some calculation like the solar panel will charge the battery during the day and the led will discharge the battery during the night, but if the led will be removed then the NiMh cells from the solar garden lamp will overcharge in time and will be damaged)
