What are my best possible battery options ?
  • TomCat58
    • Jun 2013
    • 97
    I have read many of the articles on this forum about storage batteries and find there is so much to take into consideration my head starts spinning like the girl on the "The Exorcist" Movie.. lol
    So let me try to find out the answer to my question by explaining my system. Then perhaps it will be simpler to get a answer.
    My solar boat project:
    (2) 12 volt panels with a total of 260 watts and rated at 7amps each. So 14 amps total @12 volts
    (2) Walmart MAX 96 series 29 deep cycle batteries connected in parallel 114 amp hours @ 1AH. each. So a total 228 AH @1AH total. Correct ?
    (1) Morningstar sunsaver 15amp MPPT controller. The controller doe s low voltage disconnect at 11 volts and I have that figured out that to be a 20% discharge with 80% of the charge remaining. So that is my targeted max discharge.
    SunSaver MPPT, Morningstar Corporation, Solar, Charge Controller, 15 Amp, Maximum Power Point Tracking
    The load I will consume is with a small trolling motor at lets say 6 to 9 amps draw continues.
    My question is Batteries ? I went with the walmart deep cycle because of cost but now I would like to know if different batteries would be better for my system ?
    PS The amount of solar panels will remain the same. The charge controller will remain the same also. The only improvement easily made is with the battery types.
    TomCat58
    So much wrong here not sure where to start.
    You got a trolling motor and they use 12 volts. That mean you need a 12 volt battery period end of story.
    With only 260 watts of panel wire either in series or parallel with a MPPT controller is not going to do a lot. So you have a 12 volt battery rated @ 228 AH and with a 9 amp load to discharge down to 50% do is real simple math of H = AH/A = 228 AH / 9 Amps = about 12 hours.
    However there is no way on God's Green Earth a 260 watt solar panel will ever generate that much power in a day. At best if you live in Phoenix on 4th of July the best you could generate is 30 amps hour or about 5 hours run time on the motor. In average town USA more like 2 to 3 hours.
    Lastly you will not use the LVD on the controller as that is only for small loads and useless. It is made to run low wattage lights. not motors.
    • PNjunction
      • 2179
      Don't forget that the solar insolation for Spokane is about 5 hours summer (good!), but the flip side is about 1-hour in winter. Sunrise-to-sunset is a different story, but charging is calculated on solar insolation, so this project is going to be really hard / expensive especially if your panels are not fixed on shore.
      • TomCat58
        • Jun 2013
        • 97
        I am just asking what my battery type/brand options are.
        Sunking:
        This boat is already built. It has taken me down the Colombian River on a 5 day/night trip on just solar power already. I traveled 8-9 hours a day everyday. No generators no shore power. Just these 2 panels. I know it works. As you advised me before to switch from a 30amp PWN 30amp meter morningstar controller and gain possible 30% more power out of the controller. I have done that also....I now have a morningstar 15amp sunsaver MPPT controller with a rated 97% efficiency. NOW what I am asking is how or if I can farther improve the the solar system with better "Batteries."
        I can re-post a youtube video of my Columbia River trip if needed to show you the system works and yes I was on "God Green Earth" the whole trip.... This question is about "batteries" I only posted the other components because it could relate to my what would be the "BEST" Batteries for my system.
        TomCat58
          Originally posted by TomCat58
          Sunking:
          TomCat58
          Well, if you had some reason to limit the weight of the batteries rather than being happy to have the ballast for stability, Lithium chemistry, as found in high end aftermarket motorcycle batteries might make sense. But it would be expensive and a half. And it might not be compatible with your current charge controller.
          Since you do not have either a high discharge or charge rate for the size of the bank, going to AGM does not seem necessary, although it would also reduce the weight some compared to flooded.
          So it now comes down to marine hybrid (cranking and cycle use combined) batteries versus true RE type deep cycle batteries. The latter weigh more for the same capacity and cost a bundle more, so, at least while you are experimenting, I would not recommend that.
          Once you have settled on a battery capacity and panel size and used the boat for a year or two you can revisit the battery question, IMHO.
          • TomCat58
            • Jun 2013
            • 97
            A video simi complete solar boat
            This is my solar canoe project in the works and is no where complete. But for showing the solar canoe to Sunking it should work. Taken from Oct.15th through Oct. 10th 2013 Location starts just south of the Canadian border and ends just before Grand Coulee Dam on the Colombia River.
            TomCat58
              If I was doing it, I'd use 2) 6V 200ah class batteries, wired in series to make a 12V bank. But no more than 200ah @ 12V. That's all the battery you want to kill at a time. I'd buy the 6v 200ah batteries that cost about $100 ea. They will be flooded batteries, and you will need to check/add distilled water monthly.
              • FloridaSun
                • Dec 2012
                • 634
                TomCat58
                Read Sunking's sticky again...
                Peukert Law, Batteries, and You Time for another STICKY THREAD. This is more bad news for you off-grid battery folks. Peuket law is like Death and Taxes, you will
                Pulling a 9amp load from your batteries? You do not have 228Ah available. That 228 figure is with a 1amp draw.
                How on earth do you figure 11volts to be 20% discharged??
                Would be useful to know your daily motor use along with your daily panel production, Wh. You might consider getting a few Turnigy power analyzers (wired to both sides of battery, power in and out) that would show you this info with their logging feature. Your batteries are fine, made for trolling motors, cheap, easy available. Put your money into knowing just how much juice you have available to determine when to pull that ark out of the water before you have to paddle all that weight ashore. Stay safe, breathe air not water.
                • TomCat58
                  • Jun 2013
                  • 97
                  Thank you Mike, That would almost double my AH. I will open and read the links you posted. I am wondering the time it takes to charge my batteries v those 6 volt batteries would be twice as long or what ? Having twice the AH would be a big improvement improvement as long as it doesn't take "twice" as long to charge them back to a full charge.
                  This is the kind of answers I was hoping for when I posted this thread
                  I don't know much about volts and amps YET ! But am I correct that hooking to 6 volt batteries like these:
                  We stock a wide variety of deep cycle batteries. We carry flooded, industrial (forklift type) sealed AGM, Lithium, and standard deep cycle batteries. Any purchase from us includes technical support for the life of the system. Buy with confidence.
                  In series to get 12 volts would still be 220 Amp's ?????? or am I doing the math wrong ???
                  TomCat58
                  • Wy_White_Wolf
                    • Oct 2011
                    • 1179
                    deleted
                      TomCat58
                      Putting two 6 volt 200AH (the H is important) batteries in series will give you 12 volts at 200 amp hours, yes. You would have a total of 6 cells for which to check SG and add water.
                      Two 12V 100AH batteries in parallel will also give you 12 volts at 200 amp hours, but will be harder to maintain and will probably not last as long. You would have a total of 12 cells to check and maintain.
                      One 12V 200AH battery would be twice as heavy a unit to move around and would cost more if you find one because it would be a specialty battery.
                      It is true that if you use twice as much energy from the battery bank before recharging, it will take up to twice as long to recharge. The Bulk stage will be twice as long, but the Absorb stage, where you are not currently using the full output of the panels, may not take much longer than now. But it will be your choice as to whether you use that additional energy (in an emergency, for example, or when it gets dark before you find a good campsite) or do not use it. It is a cushion.
                      But having twice the AH will give you better performance from the motor and more efficient charge utilization because Peukert's law would not be reducing the energy you can take from a fully charged battery because of the high discharge rate. So for the same amount of charge from the panels, you will get more energy to use for the motor with the larger battery bank.
                      BTW, the other pages on the smargauge.co.uk site are very helpful and many are even oriented toward boats, just not canoes.
                      • TomCat58
                        • Jun 2013
                        • 97
                        FloridaSun, I am a rookie on electricity but am learning a little everyday. " How on earth did I figure a 20% discharge" ? I simple hooked up my 120 volt battery charger right after I experienced a LVD low voltage disconnect from my Solar Controller. My battery charger has a led that tells me voltage or with the flick of a switch the percentage of charge in the battery (80%) it might not be real accurate but I am hoping close enough. My battery charger: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
                        Sunking goes crazy when I say this BUT ! Sunking tells me NOT to hook the trolling motor to the load and connect ONLY straight to the Battery. But that is not what Morningstar tells me. By running through the Load I can read the information on the controller meter 1. my battery volts 2. my amps coming from the solar panels. 3. my amps being consumed by my trolling motor. The can be seen in the video I posted here the panels are generating 9 amps and the trolling motor consuming 8 amps. SO I then know I am running with solar panels only while possible still charging the battery with the extra 1 amp....... The controller: PS-30M http://www.morningstarcorp.com/en/su...m?Name=ProStar
                        Well after talking with Morningstar tech's I was told what I am doing is OK IF I installed a diode in the trolling motor so I would NOT get any spikes back to the controller. I also never use the load connections to run the trolling motor over 14 amps draw. The controller has a 30amp "load" rating.
                        Now as far as having to row back to shore. I have taken this canoe out on lakes and rivers all over this area including 100miles the 1200 mile long Columbia river. I am never more the 2-3 miles from shore. I would guess 35 to 40 days I had it in the water so far. From a few hours to 10 hours per day. When the LVD shuts down I have a backup. Its a simple battery selector switch. Number 1 is power from the load on the controller and number 2 is wired strait to the battery. This switch allows me to not have to row. I simple switch the battery switch to number 2 and I am now drawing power straight from the battery. Then I would slowly and gentle return to the land at about a 2-3 amp draw which on calm water and little wind is about 1 mph.
                        So back to the batteries question. I have maxed out with 2 solar panels, I have now a MPPT morningstar controller with 97% efficiency and a 15 amp LOAD limit and the choice to read my amps volts etc. OR switch to straight battery. Now seek the knowledge and products (Batteries) to see if its worth changing my walmart deep cycle batteries.
                        • TomCat58
                          • Jun 2013
                          • 97
                          I read through the Peukert Law article you posted above. So tell me if this website with its excel spread sheet calculations testing a trolling motor and battery a good example of Peukert Law ? I plan to use the blank spread sheet he created and shared on his website to test my new controller and whatever batteries I end up with come spring time. Its 10 degrees out here today so not a good time to spend a few days testing right now LOL
                          By the way... "Thank you" for helping me improve my project and teaching me instead of criticizing and saying it can't be done. Sunking may be a wealth of information but his knowledge is no good to anyone if he has a "I know it all" "It won't work" attitude ......
                          Check out this website mike
                          TomCat58
                            It is a perfect application of Peukert's law, just in a simplified form where N is empirically determined by the battery specifications at two discharge rates for a particular battery model rather than being predicted for a particular battery chemistry and construction.
                            It is worth noting, as described in the smartgauge site, that for general applicability one of the two measurement points should be the C20 capacity.
                            The values which are shown in the example output are a good illustration of how important the Peukert effect can be in a typical trolling motor application.
                            And it shows that once you are into the range where the effect is strong, a charge meter which just counts up the current used will not be a perfect indication of remaining battery capacity.
                            Using the values in the table, you can see how doubling the battery size (cutting the current to capacity ratio in half) will give you extended run time for exactly the same amount of charging input into the battery.
                            This will NOT be directly applicable to the extent that your panels are providing current directly to the motor as well as charging the batteries.
                            • FloridaSun
                              • Dec 2012
                              • 634
                              haha, 11 volts to me means dead battery. I rarely let my landlocked bank get less than 24.4V (that's 12.2 for your 12v system). Different use altogether tho as I don't draw high amps like a trolling motor. Doubt that charger reading makes any sense.. let that battery sit there a while without charging and voltage will climb when the battery balances out inside. (Sunking is better at describing battery chemistry than I.)
                              Most cheaper charge controllers do have a very small amp value on their load terminals, but Morningstar with better design/construction will let you draw more. I'm a Morningstar fan myself and have read the manuals. Your battery selector switch seems redundant, the only advantage you get is not having to watch your voltage. "Then I would slowly and gentle return to the land at about a 2-3 amp draw which on calm water and little wind is about 1 mph." Designing a boat for ideal conditions can get you in trouble, wind, tide and current do not always agree with where you need to go.
                              oh yeah... back to the battery... single string is always better than parallel and a pair of 6V would be better. If you have a need to spend money AGMs would eliminate cell checks and give you a faster charge time with a bigger charger. Concorde SunXtenders good choice. Read the info at Trojan , Concorde , and others to decide what suits your needs. Use the 5-8Ah capacity rating which applies to your use better than 20-24 hour rate. The knowledge is out there. It takes time to research. You can do it yourself or listen to Sunking's (his name should be BatteryKing) excellent advice.
