Originally posted by MikeSolar
View Post
250w panel for my truck
Originally posted by boostinsteve View PostIt is 40 amps on the output. The 20 amps out is for the load connection. There is a somewhat programmable load relay. At the bottom of the controller there are 6 connections, pv +and-, battery + and -, and load + and -. It will give you the full 40 amps output to the battery though.Comment
Originally posted by MikeSolar View PostBit confusing the way they state it. "20A discharge current". Maybe 40 A through the battery but only charge the battery with 20A. I have to admit that it won't be often that we can charge the battery with more than 20A anyway. This application has the panels at a flat 0deg.Comment
I started using these when they came out a few years back. Currently I use two of them with two 245w panels while camping either on separate banks or paralleled onto one for faster charging. At $102 shipped there is no remote temp sensor or voltage sense line and the VOC limit is only 42v but that works great with a single 24v panel. http://www.eco-worthy.com/catalog/mp...ing-p-182.htmlComment
