charging station for tricycle (rickshaw)
  • solarstation
    • Nov 2013
    • 4
    Hello,
    I have the project to build a charging station for tricycles (rickshaw) using solar panels.
    Each rickshaw has a set of 5 batteries, each battery is 12 volts and 120 ah. So for each rickshaw, the accumulator is 60 volt and 120 ah.
    I need to charge each rickshaw, a set of 15 solars panels of 100 watt (5 panels connected in series to receive 60 V voltage and 3 rows connected parallel to receive 15 A current)
    Therefore, if I want to charge 10 rickshaw every day during daytime, I need 150 solar panels and a total power of 15 kw
    Are my calculations rights ?
    Thanks for your advices and suggestions !
    Are you serious?
    • solarstation
      • Nov 2013
      • 4
      Are you serious?
      Yes we are very serious.
      I wanted to add that we plan to charge the rickshaw using only a charge controller (directly with DC current from the panels)
      Any suggestions or advices ?
      Any opinion on the charge controller we should use ?
        • 15124
        Does anyone even make a charge controller for a 60 volt battery system?
          you may need even MORE panels. They never seem to meet the factory spec, and produce less - just like car mileage claims.
          • FloridaSun
            • Dec 2012
            • 634
            MidNite Classic, "12-72V battery charging standard with models up to 120V battery bank"
              Midnight Solar controllers will do that. up to 72V battery bank settings. Pricey, if you need a bunch of them.
              MidNite Solar is the industry leader and manufacture of quality Renewable Energy System electrical components and E-Panels.
              The problem is to get enough charge, fast enough, into the batteries. plain flooded will take a pretty heavy charge, without heating, from 0 - 60% full. Then things have to slow down. There are only about 5 solar hours in a average day, not counting clouds.
              For such a large array, you need a large area with no shade. Shade is bad for solar panels. They don't work in shade.
              You will need a backup charging source, either generator, or grid powered chargers. For that many stations, you will need several medium size generators, or charge fewer bikes.
                • 15124
                I must be getting old. How could I have forgotten about that puppy.
                I think it was the 60 volt battery system that had me going thinking most off grid systems are designed for 48 or 24 volts.
                  The common ones are
