Proposed Solar Powered Street Sign
  • Filter
  • Proposed Solar Powered Street Sign
    Hi guys, I'm new in here.
    Can i ask you guys for help, i'm planning to proposed solar lighting on street signs. The Dimension of the street sign is 1ft x 6 inches. Then powered by 5volts LED light.
    I want to energized it with solar panels. Is it possible to powered it with 12V, 4Ah battery? Can the 12v Solar panel charge the 12v, 4ah battery?
    hope u will help me on this
    thanks guys
    more power to solarpaneltalk
  • #2
    How many hours per day?
    How many of the lights for each sign?
    Location?
    Most street light locations at a low level will have a shortage of sun.
    • #3
      It is possible but you have not given us any details in which to help you with. Need:
      Location
      Time of year use
      LED wattage
      How many hours light will be on in a day.
      What I can tell you is a 12 volt 4 AH battery will take approx a 10 watt panel which will generate roughly 20 to 40 watt hours per day. That is not much power. Enough to supply a 5 watt LED about 4 to 8 hours. Problem will be converting 12 volts down to 5 volts. That will eat more power then the light using a series regulator. .
      • #4
        Originally posted by hgfduYtTB
        That was two!
