Plexiglass UV resistance
    What is sld in the US as plexiglass and acrylic are two VERY different materials
    • Sunny Solar
      • 510
      #62
      OK I admit I know nothing about any possible differences if any.. But if there is a difference why do USA suppliers appear call it as the same ??
      This is from a USA company. professionalplastics.
      PLEXIGLASS SHEET - EXTRUDED Acrylic
      Plexiglass Sheet (Plexiglass Extruded Acrylic) is a glazing, signage, window or display material that is unaffected by moisture, and has a high strength-to-weight ratio. Plexiglass sheet ( Plexi, or Plexy) offers high light transmittance and can be heat-formed without loss of optical clarity. Professional Plastics sells Acrylite Sheet, Lucite Sheets & Optix Sheet brands rather than Plexiglas® brand sheets. Plexiglas® (one s) is a tradename of Arkema. Plexiglass acrylic sheets may vary slightly by brand. Acrylic can be cut, routed, polished, bent and formed. Shop our online store for the best plexiglass prices delivered to your door. ORDER PLEXIGLASS CUT-TO-SIZE BELOW - ENTER YOUR CUSTOM SIZE
      If there is a difference in the material can you give exact composition of each type ?
        Well, here is what the manufacturer has to say.
        Altuglas International is a global leader in PMMA (polymethylmethacrylate) technology. We manufacture and market PMMA resin and sheet products under the brand name Plexiglas® in North and Latin America, and under the brand name Altuglas® in Asia/Pacific, Europe, Africa and the Middle East.
        The next question is whether the other "Acrylics" are really PMMA or some other formulation.
        This is a situation where I would put some reasonable faith in the Wikipedia article. Particularly:
        It is often preferred because of its moderate properties, easy handling and processing, and low cost, but behaves in a brittle manner when loaded, especially under an impact force, and is more prone to scratching than conventional inorganic glass.
        But you already know that part.
        And on the potential difference between generic "acrylic" and PMMA:
        PMMA has been sold under a variety of brand names and generic names. It is often generically called acrylic glass,[6] although it is chemically unrelated to glass. It is sometimes called simply acrylic, although acrylic can also refer to other polymers or copolymers containing polyacrylonitrile.
        • Sunny Solar
          • 510
          #64
          I also read the Wicked peadia article And I understand it to say that Acrilic glass ,Plexi glass, Perspex ,Lucite and Acrylite are just interchangable names for the same product. All those names appear to be each manufacturers name for the one product. Well thats how I read it..
          Now if someone can give the chemical compositions of Plexi glass and Acrylic glass and show they are different, Then it would appear that they are different,Cant accept an answer that simply says they are different.
            How about "It is sometimes called simply acrylic, although acrylic can also refer to other polymers or copolymers containing polyacrylonitrile."
            Containing polyacrylonitrile would definitely make it different chemically. So it really comes down to a detailed description of any particular brand of "acryilc". If it is made only from PMMA, then it is chemically the same as the original Plexiglas®. Anybody who markets something which contains polyacrylonitrile as well as PMMA would be producing something different. The particular brand names that are listed as interchangeable, like Lucite®, Perspex®, etc. ARE interchangeable. The problem is that "acrylic glass" by itself is not sufficient to insure that it is the same product.
            That said, anybody who markets their product specifically as the equivalent of Plexiglas® is probably telling the truth.
            In addition to the chemical composition, there are other things about the manufacturing process which can give the end product differing properties. But those should be less important.
            • Sunny Solar
              • 510
              #66
              This brings me back to the first question..
              If I went to Home Depot store in Arkansas and asked for a sheet of plexiglass then went to a Home Depot store in Wyoming and asked for a sheet of Acrylic glass would I get the same thing or two completely different things?
              • Sunny Solar
                • 510
                #67
                It seems its different here in Australia. the only name everyone here seems to use is Perspex..
                Even simpler in Philippines if its not glass and you can see through it its plastic.
                Like if you have a mains voltage sag or a complete blackout its a "brownout" one word covers everything.
                  John - You are tilting windmills -
                  • Sunny Solar
                    • 510
                    #69
                    Russ I dont know anything about the subject but became interested only because of someone on this thread asking about plexiglass and acrylic glass. Then when you said "they are very different materials when sold in USA..
                    I cant see any difference and from adverts in USA I cant see any differences.
                    But you say they are very different materials. so I assume you must know or im sure you would not have said that. or someone else must know what those differences are and can tell me so I and others know also..
                    I heve read all I can find on google and wikipedia,.but so far cant see any differences no matter where its sold in the world.
                      In the US if you go to a builders supply and ask for plexiglass you get one thing - roof sheeting/ greenhouse cover - may be or may not be UV resistant
                      If you ask for acrylic you get a totally different material - much more costly for different uses.
                      Polycarbonate is another selection commonly used for greenhouse covers - much more expensive that plexiglass - again may or may not be UV resistant
                      • Sunny Solar
                        • 510
                        #71
                        Russ ,,ok .. but why you not give the reply you give in #70 that I asked in #66??
                          And then there is Lexan (Polycarbonate)
                          strong, but not tough, it has a very soft surface that weathers poorly.
                          "For use in applications exposed to weathering or UV-radiation, a special surface treatment is needed. This either can be a coating (e.g. for improved abrasion resistance), or a coextrusion for enhanced weathering resistance." You will not find this version at a consumer hobby shop.
                          • KrystleGrafton
                            • 10
                            #73
                            Well to be fair looking at McMaster-Carr I see some UV "non-glare" plexi that, cut down to 11x14 sheets, would cost less than $6 a piece. That's less than half the price from americanframe AND if I can cut it to specific sizes will save me money as well by not having to order larger sizes when I need them. If I can get them cut for me before shipping likely I'll pay a bit more but still much less than $12 a sheet. And if I skimped and got the regular UV stuff it's only $3 a sheet.
                            Is "TruVue" a retail moniker or a real superior piece of plexi? I'm guessing it's just a moniker for "UV resistant, non-glare plexi."
                            wind power
                              Look at greenhouse suppliers for UV resist plexi or polycarbonate - there it is important.
                              • fireofenergy
                                • Nov 2009
                                • 21
                                #75
                                making small plexiglass panels...
                                Does any one know how long real plexiglass lasts?
                                My phone won't let me see what I'm typing so it makes more look illiterate. Anyways, the size is only 3x7 inches and I would attach the cells with a small dab of silicone on such a sandwich . Do you think the plexiglass will not yellow for at least 5 years? I can't wait that long to find out but can't seem to find real world experience on the web
                                Without massive amounts of clean energy
                                There will be no FREEDOM
