Hello everyone
I'm setting up a small solar system mostly just for emergency back up and I have a question about
setting up the battery bank and Inverter. I see some people have there batteries wired in series for 24 volts
and some have them wired in parallel for 12 volts.
I checked and the controller that I'm using will work with the batteries setup for 12 or 24 volt. I need to get
an inverter and I'm wondering if I should go with a 24 to 120 volt or 12 to 120 volts. Is there an advantage
to having the batteries and inverter set up for 24 volts?
