grounding question and confusion
    #46
    Originally posted by n8huntsman
    I didn't use that for permitting purposes. I drew up my own drawings, with borders and all the data mentioned above. I've attached it in case anyone else wants to use it as a reference.
    Very nicely done. I apologize for questioning the original drawing.
      Nicely done. You were fortunate that your AHJ did not require fireman access clearances around the arrays on the roof.
        #48
        Is that required for a single story home?
        • n8huntsman
          • Feb 2013
          • 34
          #49
          Yeah I know, I was lucky! I called and asked prior to submitting. They said, "We recommend you follow the county fire guidelines." But stopped short of saying it was required. I figured I'd submit it and see what happened. I had a plan B if they asked me to change it, but then I would have had a few panels with partial shading which I really wanted to avoid. Thanks for the words of approval on the plans! Every time I do something to my house, I incorporate it into a 3D Inventor model, so it wasn't too hard to add the panels to the roof and make drawings from that.
            #50
            On all buildings where the NFPA-1-2012 is in force.
