first - an on-line voltage drop calc for AC runs: (3% loss)
http://www.elec-toolbox.com/calculators/voltdrop.htm
Dc or AC
Voltage Drop Calculator :
http://www.nooutage.com/vdrop.htm
http://www.electrician2.com/vd_calculator.htm
voltage_drop_calculator_SolarGuppy.zip
and i found some really nifty terminals / terminal blocks for splices and taps for my AC wiring. I had to run about 900' of #6 aluminum wire, and these were some of the few things that are rated for al wire, and easier to use than the Al/Cu split bolts, if you have the right size wrenches.
POWER DISTRIBUTION BLOCKS Mfg by
And for your batteries, the terminal mount fuse blocks by Blue Sea are hard to beat.
MRBF terminal fuse by blue sea (MRBF - Marine Rated Battery Fuse)
Get the fuse & holder.
Dc or AC
