Moving to a new home with a well. Here in Tampa the water table is very shallow so I'm guessing less that 50' before you hit the aquifer. The AC unit in the home has a water cooled condenser. If I install a solar well pump will it be able to keep up with the pump run time needed for the condenser and the house? Or will I need battery backup to make it possible? 2 adults one child in the home. Thank you
water cooled condenser/solar well pump
Hi - Welcome to Solar Panel Talk!
You would need a charger and batteries. Otherwise you would only be pumping when the sun was shining.
I doubt you want the ground water passing through the AC unit condenser - usually it is not clean enough and would soon coat the inside of the condenser - They usually are not cleanable.
In that case you would need a separate loop for the ground water and a second heat exchanger.
You also want to check if you can draw ground water for that purpose. Many localities have restrictions on any once through use.
Russ[SIGPIC][/SIGPIC] -
Condensing unit is 8 years old and has been using groudwater as it's cooling source since it was installed It is not uncommon to use the groundwater to cool a condenser. There are no chemicals involved,tubes are stainless so nothing is added back into the water supply. Until the unit fails, replacing it is not an option.
I am trying to determine if using solar for the well pump is economically feasible or not. I have plenty of room for panel/panels and batteries if need be. Guess I'm not sure exactly how to calculate the requirement for a system like this?Comment
What is the size of the motor (kW or hp) and starting current if available. How many hours a day will the motor run?
If you have an AC pump you need and inverter as well.
I believe you will be surprised to see the cost of such a system.
It is uncommon to see ground water used most places actually. Not too many locations have pure enough water to get away with it.
Russ[SIGPIC][/SIGPIC]Comment
400 watts of solar can move a fair amount of water, while the sun shines. for nightime and cloudy days, you will need to either do
Grid Tie with your solar ( and use the grid as your battery )
Install batteries, and reduce efficiency by 50% for nighttime, and buy new batteries every 7 years.
I'd check with your electric utility company, and find if they have a Grid Tie policy and Net Metering Plan. That will take 95% of your harvest, and deduct it from your bill. In Florida, it will take a lot of solar PV to zero out your bill, but even a 5KW array will put a dent in it.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
This is just silly to try to do with solar battery system. Why on earth do you want to pay 10 times more for electricity than what FPL charges?MSEE, PEComment
