Here's a picture of a basic wiring diagram for my solar setup:
First question, is this wiring diagram correct? If it is, here's what I don't get. The charge controller connects to the battery via the battery terminals. The inverter connects to the battery the same way, via the terminals. So doesn't that mean that the charge controller is directly wired to the inverter? Can you just skip the battery?
So, what happens if it's solar noon, the panel is producing maximum voltage, the battery is full and the inverter has something plugged in but it only needs a little power? I'm sure there's something I'm not understanding, but it seems like because the charge converter and the inverter are both connected at the battery terminals, that they end up being directly connected as well. Maybe if the battery was low on charge, some of the power could get sucked into the battery first before going along to the inverter, but what if the battery is fully charged?
Thanks,
Rick
Thanks,
Rick
